ECM & Coolant Pump Error Codes - U0293, P261C
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Prius C Lover, Oct 30, 2025.
Tags:
  1. Prius C Lover
    Prius C Lover New Member
    Nashville,TN
    I have the following error codes: U0293, P261C
    I inspected the water pump and replaced it with a new OEM one but the error codes did not clear.
    All fuses are good but I am not positive about the more advanced relays and wiring.
    She’s got 200,000 + miles and I’d like to keep her going strong.
    Any help is appreciated.
    TIA,
  2. Brian1954
    Brian1954 Senior Member
    2,371
    954
    South Central PA, USA
    Which water pump did you replace? The engine water pump or inverter water pump?
  3. Prius C Lover
    Nashville,TN
    Engine Water pump.
    Brian1954 likes this.
  4. Leadfoot J. McCoalroller
    8,133
    7,630
    Pennsylvania
    2018 Prius c
    Your post doesn't quite make it clear- did you clear the codes using your diagnostic tool?
    Just replacing a broken part does not clear the related code(s). You have to do that yourself.
  5. Prius C Lover
    Nashville,TN
    yes, I’ve cleared the codes but they came back on.
  6. Leadfoot J. McCoalroller
    8,133
    7,630
    Pennsylvania
    2018 Prius c
    Then this is more likely a wiring issue.
    I would consult the official repair manual. It contains specific step-by-step procedures to test the wiring, it's a great resource.
    You can get an inexpensive short term subscription from Toyota, information on this link.
    Good luck!
    Prius C Lover and Brian1954 like this.
  7. Prius C Lover
    Nashville,TN
    I’m at the step for testing the power at the water pump connector while the ignition is turned to the ON position. I’m not getting power when I test for DC voltage with a multimeter or with a 12V Circuit Tester.
    It could be the wiring harness or the ECM.
  8. Leadfoot J. McCoalroller
    8,133
    7,630
    Pennsylvania
    2018 Prius c
    I don't have an active subscription right now so I can't do anything to verify your progress. That said, if the manual has you down to wires vs. ECM it's almost always the wires.
    You can use the included electronic wiring diagram to work out where the other end of that wire is and do a basic continuity check from pin to pin.
    Prius C Lover likes this.
  9. ChapmanF
    18,455
    Is that on +B, or on NWP (WPI)?
  10. Prius C Lover
    Nashville,TN
    I was unable to complete the steps in order because I don’t have Tech Stream but here are the steps I can confirm were done correctly:
    STEP 3 - CHECK TERMINAL VOLTAGE (WPI VOLTAGE)
    C27-2 (NWP) - Body ground - 6.95 Volts w Ignition set to ON - NG - NO PASS - REPLACE ECM
    STEP 4 - CHECK TERMINAL VOLTAGE (POWER SOURCE OF ENGINE WATER PUMP ASSEMBLY)
    C27-1 (+B) - Body ground - 0 Volts - NOT GOOD! - No voltage reading when tested.
    STEP 9. INSPECT RELAY (ENG W/PMP RELAY)
    3-5 - No Aux battery applied - 165 Ohms - PASSED
    I tested the 12V relay for the water pump in the dome light port and it worked flawlessly so I don’t think it is a relay problem.
  11. Prius C Lover
    Nashville,TN
    UPDATE - I tested the Engine Pump Connector for continuity and got the following results:
    C-27-2 (NWP) - A40-28 (WPI) Passed for continuity - .1 ohms
    C-27-4 (SWP) - A40-29 (WPO) - Passed for continuity
    C27-4 (SWP) or A40-29 (WPO) - Body ground - BOTH READING OL - NO OHM READING
    Still need to test the remaining connectors for continuity but at this point if I have coninuity
    but not enough power then what would most likely be my problem to troubleshoot and confirm next?
    Is there a way to confirm the amount of voltage power that is being sent to the pump when the ignition is turned to READY?
    I have the new pump installed already and the nothing seemed damage with the old pump (electronics and moving parts)
  12. Prius C Lover
    Nashville,TN
    UPDATE - Yikes! Apparently fuses only work if they’re plugged into the right slot. Problem has been resolved and the only dash light I have now is my TPMS sensor.
