1. Dale Casey Acker
    Dale Casey Acker Junior Member
    36
    Alabama
    Can someone please tell me why my valve train is sounding like this after head gasket replacement. It will only run for a few seconds bc I have the valve cover off so I could try and figure out what is going on. All the valve spring caps are on so it isn't that. I am lost here.
    51,732
    no link? how many miles on her?
  3. bisco
    51,732
    this is a gen 3 forum, i see you have a 2008?
  4. Dale Casey Acker
    36
    Alabama
    Its working on my end... try this one
  5. Dale Casey Acker
    36
    Alabama
    I also have techstream but not sure that will help with his because there are no codes related to ignition
  6. Dale Casey Acker
    36
    Alabama
    This is on another 2010 I just picked up
  7. bisco
    51,732
    all i see is 'allow google to access your cookies'
  8. bisco
    51,732
  9. Dale Casey Acker
    36
    Alabama
    198000. I just did the head gasket on it
  10. Dale Casey Acker
    36
    Alabama
    Click allow and the video should be there
  11. Mendel Leisk
    41,155
    I'd make a video, upload to YouTube, post a link here. That works seamlessly.
  12. Dale Casey Acker
    36
    Alabama
  13. Dale Casey Acker
    36
    Alabama
    I also pulled the lifters out this morning and cleaned them, made sure they were all compressing and springing back and reinstalled. No real change. And for anyone that's wondering yes you can remove the rockers and lifters without removing the timing chain and cams. It's not the easiest especially the ones closest to the gears but definitely doable. Just remove all the retainers and pry the cams up as much as you can on the free end, wedge something under them to hold them up and you can work the rockers and lifters out from under them.
  14. bisco
    51,732
    it doesn't sound bad to me. did you let the car warm up?
