Climate setting to just have fan pull air in?
Discussion in 'Gen 3 Prius Main Forum' started by Johnny Cakes, Oct 31, 2025.
  1. Johnny Cakes
    Johnny Cakes Senior Member
    1,055
    780
    Virginia, USA
    The climate control system seems to demand a cabin temperature that it will try to maintain.
    Is it possible for the system to just bring outside air into the cabin, without reference to trying to achieve a particular temperature?
    Sorta the equivalent of opening the windows. Whatever is out there, that’s what you get.
  2. Leadfoot J. McCoalroller
    8,133
    7,630
    Pennsylvania
    2018 Prius c
    We can do that in our car by adjusting the temperature setpoint to below the ambient outside air temperature and then pushing the A/C button to make the light go out, indicating that it won't use air conditioning.* Then set the fan to whatever is needed.
    I'm not sure yours will be the same, but I bet it will be at least close.
    *There are a few special circumstances where the car can silently re-engage the A/C to satisfy some temporary condition, but there are other threads about that. Personally I've never noticed or cared.
    BiomedO1 likes this.
  3. BiomedO1
    4,018
    2,109
    SacTown, Ca
    ^ Yep, that should place your HVAC system into manual mode. I usually just drop my temp. to LO and make sure the AC lamp is OFF.
  4. bisco
    52,286
    i always put it on manually, temp set to low.
  5. BiomedO1
    4,018
    2,109
    SacTown, Ca
    Mine is not a truly manual mode. On long winter drives, I can bump up the temp. setting and it'll warm the incoming air to that set point. Move the set point back to Lo, you'll get chilly outside air again.
