12v battery question
Discussion in 'Gen 3 Prius Main Forum' started by Docdkay, Aug 29, 2021.
Tags:
  1. Docdkay
    Docdkay New Member
    Is an optima low maintenance high performance agm battery good for a toyota prius or should i switch for a different one
  2. jburg
    jburg Member
    93
    RTP, NC
    Optima batteries are overpriced, but AGM batteries are the best and longest lasting you can buy.
    My original battery lasted for 10 years and I replaced it with one from Advance Auto. Believe I got it for under 200 bucks with a 20% coupon on pickup.
  3. jburg
    jburg Member
    93
    RTP, NC
    NAPA is running a 20% off discount + a $20 MIR on batteries.
    You can get a NAPA Legend battery (I believe they are made by DAKA in the USA) for around 150 to 155 bucks OTD after MIR and your return the core.
    burrito likes this.
  4. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    You may also want to check with your Toyota dealers. I was there this morning (got a new radiator cap for my daughters Sienna) and I asked them if they have any, now. (They've been on back order for months) She said they do have limited quantities and can see if one fits with a VIN number. My dealer has them for around $190, a great price, IMHO.
  5. Mendel Leisk
    41,162
    Some of the Optimas (my yellow top for example) have higher Cold Cranking Amps but lower amp hours, compared to the OEM battery. Not sure of the ramifications; suspect there are some though.
    I’m able now to source the OEM Yuasa battery for $220 CDN through Saskbattery up here. It’s NOT showing on their website, but another Priuschatter said it was doable, and I confirmed with them by email.
    they DO show Optima Yellow Top (for ridiculously high price) but told me they actually don’t have them.
  6. ChapmanF
    17,943
    I think the OEM battery has a cold-cranking-amps rating (just because a car battery's gotta have one) around 330 amps or so, and yes, some replacements will exceed that rating.
    In a car where the positive battery clamp has a 140 amp fuse built into it, none of that on-paper rating is ever going to serve any purpose.
    Typically, though, batteries are given higher CCA ratings by making their plates thinner, and that means the occasional (intentional or unintentional) deep discharge will hit them harder.
  7. johnHRP
    johnHRP Active Member
    640
    184
    KA, DE
    Excel
    The original Yuasa battery is always the best and last the longest even it has lower capacity or CCA than aftermarket. It is just well made
  8. PatrickEE
    PatrickEE Junior Member
    Michigan
    Four Touring
    I just bought Toyota TrueStart S46B24R (2008 Prius) 12V battery online at Toyota. $193.31 ($171.99 + $10.32 tax + core charge $11). To pick up at Fox Toyota, Rochester Hills, MI (Toyota won't deliver). I thought of Optima 8171-767 DS46B24R Yellow Top, but it's $290 (Amazon). My current battery is 12.43V, (rated 325CCA) 288CCA,10.55mOhm, SOH 75.7%, SoC 79%, Great (according to Motopower battery tester); that's after I fully charged (after dead battery). I will replace it myself when I get. Battery went dead more than a few times (humid, cold, etc.) recent years. It was my second Toyota battery since 2008 (lasted 12 or 15 years, can't remember; original didn't last, replaced for $300 at dealer in Toronto ~2010?).
  9. johnHRP
    640
    184
    KA, DE
    Excel
    Yuasa is identical with genuine Toyota Battery for AGM
  10. Higgins909
    Higgins909 Member
    277
    68
    My Toyota True start lasted some 90 months of the 84 month warranty. I now have some kind of Autozone AGM. I think it's about 5 years old and is probably going to fail soon. Think it only had a 1 year warranty.
  11. johnHRP
    640
    184
    KA, DE
    Excel
    I observed original prius battery last 9y in hot FL and 12y in mild weather in UK if driven regularly.
    1x depleted 12V battery that needs jump start easily cut the capacity 40% or more from the original capacity.
    Just don't ever get it too depleted, the sulphation is non reversible process.
  12. Arkay
    Arkay Junior Member
    26
    Mountain View
    2014 Prius Plug-in
    My belief is that CCA does not matter; it is the total AH (ampere-hours) that matters. The reason is that the 12v battery needs to be able to power the electronics. The rest of it is taken care of by the main high voltage battery pack.
  13. BiomedO1
    3,375
    1,755
    SacTown, Ca
    Zombie thread.......
  14. Mendel Leisk
    41,162
    Mmm, I'd say CCA does matter, in the following way: if the battery is rated with a certain CCA (say 325 per the stock battery), but tests well below that, say 200~250, you can rest assured that the battery is failing.
  15. johnHRP
    640
    184
    KA, DE
    Excel
    CCA test is a very good way to test a fully charge battery health. A bad battery won't supply enough current and maintain voltage on high load, the load voltage often drops below 10V at max load.
    BiomedO1 likes this.
  16. bisco
    51,735
    arkay may have meant that cca doesn't matter in a new battery because it isn't cranking an engine
  17. Mendel Leisk
    41,162
    That seems to be his logic, but I think there's conflation at play: the battery doesn't need to crank, but when tested, lower-than-spec CCA still indicates a battery on the way out.
    johnHRP likes this.
  18. johnHRP
    640
    184
    KA, DE
    Excel
    The CCA test is often simply load the battery at certain Amps with a giant graphite resistor and see how much voltage drop is.
  19. ChapmanF
    17,943
    That'd be any CA (cranking amps) test.
    A CCA (cold cranking amps) test is that, done at a specific cold temperature.
  20. Mendel Leisk
    41,162
    I'm using a Solar BA5, enter a couple of parameters (battery type and spec'd CCA), and tada:
