2013 prius C electric issue
Discussion in 'Prius c Main Forum' started by tonytang, Oct 27, 2025 at 10:22 PM.
  1. tonytang
    tonytang New Member
    Saint John, nb
    bought a used 2013 Prius C, not sure if it is one or two, 400K km milage.i have driven it a few days everything seems works perfectly until I got it replaced the front brake pads and right side front wheel bearing. I didn't do the job, my neighbour which is a 20+ years mechanic running a garage did the job. on the way back from the garage, I noticed some lights popped up, and speed reading started going crazy, especially when I was padding brake, it would go from 50 to 5 then 12 or anything but not the true speed. 10-20 minutes later, it showed up check hybrid system, engine oil pressure low, all the lights on the dash lights up, including, parking lights, abs, engine light, electric power steering light, slip indicator lights, brake warning light and more. So, I pulled over to the curb, and called the tow service. during the waiting, I checked the engine oil level, it is good (changed 5 days ago), coolant level and temperature, coolant is full, and at the coolant cover it is warm, not even hot. and I found two weird problem, 1 was if I pad a few times of brake, the car will turn off, just like loose power connection, the 2nd is, even if I turned off the vehicle and pulled out the key, the immobile lights keeps blinking, and something keeps clicking once the immobile lights blink.
    vehicle towed back to garage, neighbour checked everything like I did, engine oil good, coolant not overheat, OBDII read tons of error codes: p0117, low input of engine coolant temperature circuit , p0441, incorrect purge flow of evaporative emission control, P2420, evaporative emission pressure switching valve is stuck in off position, U0129, lost communication with brake system control module, c1380 malfunction of stop light relay, c1467 circuit of left rear speed sensor, U0074 communication bus of control module is off, U0124, communication with lateral acceleration sensor module is lost, U0126 communication with steering angle sensor module is lost, U0293, communication with hybrid vehicle control system is lost, U0293, lost communication with HV/EV ECU, U0101 communication with TCM is lost, U0142 communication with body control module B is lost, U0155 communication with instrument panel cluster (IPC ) control module is lost, U0100 lost communication with ECM/PCM/EV"A", U0151 lost communication with restraints control module, U0164 lost communication with HVAC control module. he is a good mechanic , but he had limited exprience with hybrid prius. and we dont understand why would this happen.
    anyone can help me on anything I should check step by step?
    appreciate
  2. tonytang
    tonytang New Member
    Saint John, nb
    when the tow truck came, I drove onto the tow truck, and the hybrid battery was working, I drove on by hybrid battery ( engine was not humming)
  3. John in Vermont
    John in Vermont Junior Member
    46
    Rochester, Vermont
    2018 Prius c
    When everything goes sideways at once I would be suspicious that your 12 volt battery has started to fail which will cause just about every piece of electronics in the car to start to throw error codes.
  4. bisco
    51,735
    get a free load test at most auto parts stores
  5. tonytang
    tonytang New Member
    Saint John, nb
    what is load test?
  6. BiomedO1
    3,375
    1,755
    SacTown, Ca
    Your mechanic should know - It's a test of the battery's capacity.
    FWIW; A Prius will stump even a good mechanic, unless they keep up with current technology and the latest diagnostic tricks. He may be able to fix an old broken tractor, but a car with multiple ECUs onboard may be another story.
  7. Leadfoot J. McCoalroller
    8,048
    7,527
    Pennsylvania
    2018 Prius c
    There may be more than one problem. I'm suspicious of the wheel bearing replacement- there is a wheel speed sensor integrated in those bearings, and when one of those sends junk data into the system lots of problems can occur.
    I had a situation with a poor quality (possibly even counterfeit) bearing replacement that really freaked out our car with many seemingly-unrelated errors. Swapping the bearing for a genuine Toyota item solved it instantly and permanently.
    That said, the list of problems we had wasn't as long and weird as yours, so I'm a bit suspicious that there's more going on than just a duff speed sensor- but that's where I'd start.
    BiomedO1 likes this.
  8. tonytang
    tonytang New Member
    Saint John, nb
    but he just replaced the bearing not the bearing assembly, basically, only push out the old bearing and press the new bearing in. we did suspect the abs speed sensor as the culprit, so we disconnected it and ran the vehicle, but nothing solved, all the problems stayed, except a new error code coming up stating lost connection of the abs sensor.
  9. tonytang
    tonytang New Member
    Saint John, nb
    I totally agree, but it is kind of too late.
  10. tonytang
    tonytang New Member
    Saint John, nb
    yep, a lot of people believe the 12V battery may affect those control units, so did my mechanic neighbour, I have showed him there were 14.1V from alternator, it didn't matter if the 12V battery work or not, however, I still purchased a brand new S34b20R and installed it on, after cleaning all the codes, 5 minutes later, more codes coming back, speed reading still showing crazy, when it is running 50, it showed 3, 14 or whatever number but not 50, every lights still on, hybrid battery still showed ready but check hybrid system, after changing the battery, nothing really change.
  11. tonytang
    tonytang New Member
    Saint John, nb
    wasting $400 + though
  12. ChapmanF
    17,943
    A lot of trouble codes. Look them up in the repair manual and start following the troubleshooting steps for them.
    Toyota Service Information and Where To Find It | PriusChat
    I would start with the U codes, which are all communication problems between modules. Your meter can't display the right speed, for example, if it can't get that number from the brake module (which is the one the wheel speed sensors connect to). You have to get all the communication problems sorted before tackling much else.
    Despite the intimidating number of codes, as you follow through the troubleshooting steps, you may be led to one obvious spot of wiring damage or the like that accounts for most or all of them.
  13. BiomedO1
    3,375
    1,755
    SacTown, Ca
    I beg to differ; your wallet is $400 geese lighter.:(o_O That's why we suggest TESTING rather than pointing a "parts cannon" at problems.
    Seriously; all your problems started with that repair - so that repair is highly suspect. The other option is that rodents started chewing on your wiring harness while the car was out of commission.
    Something is throwing a lot of 'noise' into your CAN bus disrupting the ECUs ability to communicate with each other - therefore all the unrelated error codes and funky actions of your speedometer. This is acting like a car that's been underwater, creating a bunch of ground bridges, so all your electronics are 'wigging-out'.
    I would start by inspecting the wiring harness for shorts and chew marks; especially around the repair area. Source a used wheel hub assembly with either a new or used sensor and replace the one that was just repaired to rule it out. Don't know how those wheel sensors are wired together or report to a common point - you'll need to consult with the car's wiring diagram. Seems strange that your rear left wheel sensor kicked an error code - you may want to look there too. Sometimes those wires gets snagged onto some road debris and get ripped out and shorted together.
    Good Luck.....
    I once had an apprentice broke a couple of teeth off of a half shaft replacement and didn't say anything. Took the car for a test drive, before handing it back to the customer, only to find a bunch or ABS/Traction control error codes popping up. We called it a defective replacement half-shaft and had to keep the car for another day....... The shop's reputation would've took a big hit; if that slipped by our QC - Needless to say; an apprentice that's too liberal with a hammer isn't going to last and would eventually start costing the shop time and money.
