Heater fan groan
Discussion in 'Gen 2 Prius Main Forum' started by qmanqman, Nov 1, 2025.
  1. qmanqman
    qmanqman Active Member
    439
    152
    CO
    Now that it's cold and I got the heat on from time to time the fan will kind of make a groaning noise intermittently. Not very often but every now and then. Is there a simple and easy way to lube the fan without having to tear the dash apart and pull the Box out?
  2. Tombukt2
    13,341
    2,402
    Getting time for fan motor no taking dash apart 3 10 mm move a piece of plastic . Blow out hole and vac it w shop vac. Put in new .
  3. pasadena_commut
    pasadena_commut Senior Member
    2,803
    834
    Southern California
    Does it make that noise if the fan is run and the heat isn't on? If not, it might be air in the heater core rather than the blower itself. I don't recall if the Prius has a valve that controls whether coolant goes through the core. On cars that do those sometimes make noises when the valve opens or closes. Same thing with blend door actuators.
  4. qmanqman
    439
    152
    CO
    Duh don't know why I didn't search YT first.
    #4 qmanqman, Nov 2, 2025
  5. qmanqman
    439
    152
    CO
    Daughter says it doesn't happen with the A/C but it's not cold in the summer. I'm pretty sure it's the fan because you can hear the fan running and then that sound changes. My 72 F100 did the same thing and I just lubed the motor and fixed it. I was just wondering if it's hard to get to.
  6. Tombukt2
    13,341
    2,402
    When you pull the fan down and you look at it carefully you will see a bunch of shiet inside the motor you try cleaning all that out and see
  7. qmanqman
    439
    152
    CO
    Blew it out with air and squirted some light compressor oil at the bottom bushing area. Quiet as a mouse now.
    Tombukt2 likes this.
