IV discharge curves for a working Prius 12V battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pasadena_commut, Mar 8, 2023.
  1. pasadena_commut
    pasadena_commut Senior Member
    2,700
    806
    Southern California
    Anybody have a link to a table or plot of I vs. V for a healthy Prius 12V battery at various SOCs? The AGM battery Toyota sells, not a generic AGM plot.
    The 12V battery in my car tested "good" at the auto parts store today (not sure what model tester but it was big and brick shaped and had a small fan blowing to carry off heat), and also with the little Harbor Freight battery tester:
    12V Digital Battery and System Tester
    However, if it is 12.51V with the car off (~20mA load), it falls to 12.31V with ~1A load (car to READY, then off, fob left plugged into dash), and 12.15V with 2.22A (ACC mode). Current measured with a UT210 ammeter clamp on the ground strap, and voltage on the battery posts, in all 3 cases. The spec for the battery is 320 CCA, which is about 45 Ah. 1/45 = .022C and 2.2/45 = .049C. Looking at the first table "Open Circuit Voltage of AGM Battery" and second table "AGM Battery Voltage under Discharge Condition 0.1C" here:
    https://sunonbattery.com/agm-battery-voltage-capacity/
    we see that the battery was initially about 70% charged. From the second table, at 0.1C (4.5A) that should be a voltage of around 12.15V (extrapolating between 60% and 80%). So .36V drop due to the current, if this was the reference battery. Measured on the battery in my car though it is 12.15V at .049C. That is, it acts like it has twice the internal resistance of the battery in that link, if all of the voltage drop is assigned to that factor. An IV curve or table for the same type battery would tell me if they are all like this.
    The HF tester says the battery has internal resistance of 8.3 to 8.6 mOhms, which is higher than the 2 mOhms usually cited for an AGM battery. It was also 3 times the internal resistance measured on an old conventional 12V truck battery.
    All discharge tests show the battery capacity (in CCA or Ah) is close to that on the label. Yet the battery charges to "full" from 12.5V (no load) in less than 5h15m on a Battery Tender Junior, which is nominally 0.75A. .3 * 45 = 13.5A, but .75 * 5.25h =~ 4Ah. In other words by charging rate it seems to have less than 1/3 of the capacity. It has done this twice now, with slightly different times, probably because the temperature was different.
    So by some measures this battery is good, but on others (like charge time) it is way below capacity. Something odd is going on. This unit is still within 2 years from when it was purchased, but I'm pretty sure if I show up at the dealer they will just slap it on a tester like the one at the auto store and declare it not only good to go, but as good as new! (I started looking at this because MPG had fallen to around 40. When in use it seems to be dropping voltage much too fast. The car isn't being driven much, but charge all the way and reinstall and it falls down to 12.2V on the MFD in ACC in a couple of days. The MFD shows 14.1V in READY mode.)
    I also looked high and low for a parasitic load that might have damaged it or be dragging it down. Couldn't find one. Once the car settles down it goes to 20 mA, which is normal. I cannot rule out that it wakes up in the middle of the night and runs something, but there is no evidence that it does so. The only consistently weird thing I see now is that when checking the voltage in ACC mode there is always a glitch briefly (one reading) up above 13 volts a minute or two minutes after starting to look. Today it was reading 12.0V and jumped to 13.4V, then back down again. That one I really don't get - either there is some other stored energy briefly brought into play, or the MFD consistently misreads or misdisplays one value around that time point.
  2. Tombukt2
    13,117
    2,355
    If it's not failing and your car is running great fine whatever then there's not much to supplier Toyota AutoZone Menards whoever can do. Right? So just short it out real bad with a you know solid piece of metal till it bakes internally and take it in and say it failed then I imagine you'll get a prorated rate on the new battery.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,062
    1,981
    NJ-USA
    Don't know about voltage-current charts. It sounds like the store used a carbon pile resistive load tester. It has a knob that compresses a number of carbon discs, creating an "adjustable short" across the battery cables.
    You set it to half the CCA rating (160A for 320CCA) then read the voltage after 15 seconds just before removing the load. Pass / fail is 9.6V at 70°F, with temperature compensation down to 8.5V at 0°F.
    That test or other (capacitance) testers will catch most faults. They won't always find problems that cause self discharge.
    You might have to wait until your battery actually "fails", or buy another one yourself.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    OR.....he might have to obsess over this......and waste tons of time and effort chasing a ghost.
    Like he is doing now.
    Note: The health of the 12 V battery......or lack of it......should have NO impact on your gas mileage because it is being CHARGED while the vehicle is running and has no impact on the operation, unless it is so sick that it presents an effective short.
  5. pasadena_commut
    2,700
    806
    Southern California
    Nice theory. The problem is that observations don't agree with it. It is a common observation that MPG decreases as the 12V battery declines. The last time I had a 12V battery die exactly the same thing happened - the MPG became progressively worse, and it jumped right back up into the 47-49 range when the new battery was installed. This time I noticed the MPG dropping and subsequent testing of the 12V showed that it was indeed on the way out. I think the fault in your logic is exactly that it is being charged, and charged, and charged, and that must not be very efficient, because it shows up in the MPG.
    I ended up driving the car over to a dealer today to see if they could/would test it. Before doing so two different people on the phone insisted that the battery must be in the car for them to consider warranty, and it has to go to service. When I get there, of course, service said exactly the opposite: it has to be out, and go to the parts department. They kindly offered to test it, with the caveat that they would bill $190 to reinstall it (or the replacement). I did eventually get the service manager to confirm that the "test" was indeed just plugging it into a conventional 12V battery tester. I knew it would not fail that, as I had already tested it that way. By my calculations the battery has a capacity of about 12.5Ah (roughly1/4 of a healthy battery), but that sort of test only takes 1 to 3 Ah out, so it would certainly not collapse the voltage enough to fail. A Prius 12V would need to get down to 5Ah or less to fail that test. So I left.
    For future reference, here is how to figure out the capacity (if no external load is available). Unhook the battery from the car. Charge the battery to max, let it sit overnight. On this battery it was 12.74V. Reattach it. Put the car in IG-ON with all lights off, all doors shut, AC off, cabin fan at 3rd highest setting (one above the middle). On my car that resulted in nearly exactly 20A current coming out of the 12V battery. Drain for 15 minutes. Turn car off and wait 20 minutes or so for the voltage to recover (all doors closed, car locked). That was 12.22V. Look up those voltages on an AGM SOC table. Top one is 90% SOC, bottom one is 50% SOC, and 5Ah out. So divide 5 by .4 and get a capacity of 12.5 Ah (roughly, not sure how big the error bars are.) This would probably be close on any Gen 2.
    Maybe worth putting this thing on a modern 4A charger and see if the high frequency mode improves capacity any. I have a HF 4A charger
    4 Amp Fully Automatic Microprocessor Controlled Battery Charger/Maintainer
    but it isn't clear that it goes into any sort of special restoration mode unless the battery is very low. As is typical of their documentation, it is pretty vague about exactly what it is doing. CTEK makes better chargers, but their 4A model is actually 4.3A, and supposedly this Prius battery should not be charged at over 4A. I had the HF charger on for a couple of minutes, just to test, and it was only putting in 3.8A, so below that limit.
  6. Mendel Leisk
    41,644
    I've been testing our batteries with a Solar BA5* for over a decade now; battery installed, only stipulation being you need to connect directly at the posts? Am I missing out on something?
    What does "IV" mean, by the way?
    * Current version is BA9 I think.
    #6 Mendel Leisk, Mar 10, 2023
  7. sam spade 2
    7,035
    2,804
    2017 Prius c
    I call BS.
    I've been here for over 5 years and YOU are the only person I remember ever making that claim.......for a battery that still tests well within the "good" range.
    And I think your conclusion is flawed.....big time.
    But it's obvious that you just like to show off your "knowledge" so go right ahead.
    Others can draw their own conclusions.
    alftoy likes this.
  8. pasadena_commut
    2,700
    806
    Southern California
    Isolating the battery from the car while charging and resting avoids the possibility of any intermittent parasitic load changing the "full" voltage. It is also 100% safe - a charger cannot blow up delicate and expensive Prius electronics. This is more of a concern for larger currents. When trickle charging an already mostly charged battery I wouldn't worry as much, since the trickle charger is designed to run in that mode. That said, I once tried to charge a different battery through the open hatch, which worked poorly, since it was only a .75A charger and "door open" causes a .5A drain even though no lights were on. Had the battery been disconnected, it would have worked as intended.
    No safety reason to disconnect the battery when testing as long as the car is well and truly off.
    IV is current vs. voltage. It is a common plot for things like diodes or transistors. For a given SOC V will go down as I goes up. Made up numbers for 100% SOC might be
    0A 7.8V
    1A 7.7V
    2A 7.5V
    and so on. This information is usually plotted as V vs. SOC for constant I, as in this plot
    https://www.researchgate.net/figure/Li-ion-cells-voltage-curve-at-different-discharge-rates-at-25-o-C_fig8_4185795
    I thought it might be one way to determine the SOC from the ACC voltage value, as current in that mode had been previously measured.
  9. bisco
    52,093
    When the 12v is constantly low, the inverter needs more energy from the hybrid battery which causes the engine to run more
  10. pasadena_commut
    2,700
    806
    Southern California
    Back to what an IV curve is, here
    What Is the Charge Voltage of an AGM Battery?
    there is an image: AGM Battery Discharge Voltage Chart. It has V vs. I for given states of charge. The only thing is, I don't believe this is from measurements on a real battery - the values are too perfect. In any row the 2nd voltage is always exactly 1.0 less than the first, and the third is .6 less than the second, for instance. However, it does illustrate the concept. The table is copied here in case the source ever goes away.
    I just ran a quick discharge test as above in post 5 which was 20A for (only) 10 minutes, voltage 25 minutes before was 12.66V and 25 minutes after 12.37V. During the discharge the voltage at the jump point was 11.28V the entire time (sometimes .01 or .02 lower, but with no pattern). The measured voltage during discharge does not agree with this chart since depending on the SOC table consulted even the lower one is well above 50%, which should have been 11.40V, and at the starting point it should have been 12.2V or thereabouts. This battery is now 2 years older than it was when post 5 was made, perhaps under the test conditions it is no longer supplying 20A, or it is only 20A when the voltage on the battery was at a certain value?
  11. pasadena_commut
    2,700
    806
    Southern California
    Also my "estimate the capacity" method ignores Peukert's law. Largely because I have never seen the technical spec sheet for the OEM battery and so don't know the current at which the capacity is rated or the exponent value. More info:
    8. Battery capacity and Peukert exponent
  12. dolj
    dolj Senior Member
    8,458
    4,294
    Wellington, New Zealand
    My giddy aunt!
    Paralysis by over-analysis, maybe.
  13. pasadena_commut
    2,700
    806
    Southern California
    Recently I bought a DLT150 configurable electronic load and after charging the battery fully and letting it rest overnight discharged it for 2 hours at 2.5A (at temperatures between 20 and 25 Centigrade). The current drawn was confirmed with a DC clamp ammeter. Starting VOC 12.76, ending VOC 12.35 (both with the battery detached from everything after resting at least an hour). While it is nominally a 45 Ah battery, by my calculation and the AGM table I used that 5Ah corresponds to a delta SOC of 49%, giving a capacity of 10.2 Ah. I know the correct way to measure capacity is to discharge all the way down to 0% SOC at C/20 (which would be 2.25A but 2.5A is close enough that the Peukert's correction would be negligible) but I didn't want to drain this battery below 50% SOC. By chance the 2 hour discharge actually ended very close to 50% SOC because the battery had so little capacity.
    What does the tester say?
    Recharged the battery, let it sit overnight (>12 hours), and tested it with the HF "Viking" tester (set for AGM flat plate, Ah mode, 45Ah reference), with this result:
    SOH 83, SOC 100, Ah 43, 12.79 V, 8.66 mOhm at 24.2 C
    The tester also has a 320 CCA marking, so tested in the CCA mode too (only a minute later) and found:
    SOH 100, SOC 100, CCA 346, 12.76 V, 8.66 mOhm at 23.6 C
    Just for yucks and because it was already out of the car took it to an Autozone and they ran a CCA test, which of course it passed.
    In short, the measured capacity of 10.2 Ah is far below the 45 Ah label capacity, but the quick electronic testers are oblivious to this.
  14. pasadena_commut
    2,700
    806
    Southern California
    Here is the discharge plot. This is the discharge curve, which looks nothing like one from a healthy lead acid battery. The two points after 120 minutes show the battery returning to its final VOC.
  15. pasadena_commut
    2,700
    806
    Southern California
    Now that I have observed that 2 out of 2 impedance testers were useless for making battery capacity measurements I have found numerous other web sites where people came to the same conclusion. For instance:
    Are Battery Conductance Testers Worth It? - Marine How To
    There he shows a Midtronics tester also failing to detect capacity loss. I believe Toyota uses Midtronics, although possibly not the same model. Convenient (for them) that they employ a testing method which typically cannot detect a battery which has failed due to lack of capacity, no?
    So, if a person wanted to know the actual capacity of a Prius's 12V battery how would they determine that without having to buy a DLT150 or similar discharge unit or remove the battery from the car? A pretty good approximation can be had using the car itself as a load. In this thread:
    Current by Power State and Option combinations | PriusChat
    I measured the current drawn from the battery with the car in one of its power states with various options turned on (or all off). The ACC mode, with everything else in the car off, pulled 2.4A from the auxiliary battery. This was with the not so great battery in the preceding plot. A healthy battery would probably have a tiny bit more current because it would be a higher voltage. But not much higher voltage, at most 13 V, and if the resistance is constant (it probably is not, and it probably varies with temperature, but let's ignore that), that would only be 5% more current. 2.5A isn't C/20, which is 2.25A for a stock battery, but it is close, and the Peukert correction would be very small. This method assumes the test car does not have an abnormal current load above and beyond what ACC pulls normally and that the current drawn is approximately 2.5A. The battery should be fully charged for this test.
    So, to measure the capacity using the voltage at the jump point do:
    1. Open the hood
    2. Roll down the driver side window all the way
    3. Turn the car off and exit the car. All lights should be off.
    4. Let it sit at least 1 hour (battery goes to "VOC", ignoring the 20-25 mA parasitic load as "small")
    5. Measure the voltage at the jump point = Vstart
    6. Lean through the window, put the fob in, press the power button once, note the start time
    7. Wait exactly 2 hours
    8. Lean through the window, turn the car off, remove the fob
    9. Wait at least 1 hour (battery again goes to "VOC", ignoring the 20-25 mA parasitic load as "small")
    10. Measure the voltage at the jump point = Vstop
    Using an AGM SOC table, calculate:
    Delta_SOC = (SOC% at Vstart) - (SOC% at Vstop)
    Capacity = (2h * 2.5A) * 100/Delta_SOC = 5Ah * 100/Delta_SOC
    A battery in truly desperate condition might completely crash during this test. So it would be prudent to measure the voltage at the jump point from time to time and shorten the test if it ever falls below 12.0V. If it falls below 10 or 10.5V the car would likely shut itself off. The capacity can still be determined, just change the 2h in the last equation to reflect the shorter time.
    This method should work for any AGM battery, not just stock batteries. It would not work for Lithium ion, Sodium, or other types of batteries. Even if the SOC table was available many of these have very flat discharge curves and the measurement would be difficult to do accurately on this short time period.
    Edit: In case it isn't obvious, keep an eye on the car. It is sitting there with the fob in the ignition. So do this in the garage if at all possible.
    #15 pasadena_commut, Nov 2, 2025
  16. pasadena_commut
    2,700
    806
    Southern California
    Sorry DTL150, not DLT150. For many years at work we used DLT tapes, and I had a PVC/PCV moment.
  17. pasadena_commut
    2,700
    806
    Southern California
    The battery in post 14 was actually a S34B20R battery. It wasn't marked that way, only a part number, no size indicated, but it was smaller than the replacement Walmart S46B24R battery. I had to change the battery "tray" (the metal piece it sits on, isn't really a tray) for a larger one from the junk yard. The weight of the Walmart battery is 14360 grams. (So this time I can see how fast it dries out in the hot S. California climate by weighing it.)
    Here is the discharge curve for the new Walmart battery after it had been fully charged and the surface charge removed.
    Note the absence of the weird bulge at the start of the discharge that was present in the preceding battery. Also of course the voltage on the new battery is much higher after the 2 hour discharge, 12.70V vs. 12.35V. Both discharge curves were with the battery completely disconnected from the vehicle.
    #17 pasadena_commut, Dec 1, 2025
