Attention Battery Rebuilders! ToolkitRC M6D Chargers anyone?
Discussion in 'Gen 2 Prius Technical Discussion' started by ozmatt, Nov 3, 2025.
  1. ozmatt
    ozmatt Active Member
    637
    263
    Australia
    Hi all :) previously asked this question in historic battery threads but it never gained much attention so decided to start my own thread.
    So I purchased a few ToolkitRC M6D chargers but having problems with runaway charge, they are just not cutting out, ever. I went for these because they are tiny and capable of 15a discharge rate in recycle mode, attractive proposal!
    Downloaded and installed the latest firmware, cables are 14awg turnigy silicone 250mm long, current settings are 4 amp charge and the lowest selectable "nixx peak" setting of 5mV but they just keep charging to the moon and blowing modules up until the relief valves pop, btw im only testing with low capacity junk modules and very well aware of the impact on modules charging to this point, I have done extensive testing over the last decade with my old chargers but I want to make a nice new test station with maybe 14 channels to get things done more efficiently
    One thing that's not clear to me about these chargers is if the selectable peak (5mV to 15mV ) is per cell or for the complete module, i don't want to give up on them but meh its getting pretty annoying at this stage.
    Has anyone else had a go at these little beauties yet?
    #1 ozmatt, Nov 3, 2025
  2. dolj
    dolj Senior Member
    8,546
    4,341
    Wellington, New Zealand
    I presume you mean millivolts (not megavolts, as written), in which case the abbreviation is 5mV and 15mV respectively. The abbreviation for megavolts is MV.
    ozmatt likes this.
  3. ozmatt
    637
    263
    Australia
    Yes sorry millivolts is what i meant
  4. Hayslayer
    Hayslayer Active Member
    459
    264
    I have zero experience with, or knowledge about, that charger.
    My suggestion would be to try it using one good module and see how it acts. Consider it a sacrifice to the charger gods.
    A low capacity module with a high IR is going to make the charger go to a relatively high voltage to hit that 4 amp setpoint. Record that voltage and then try it with a good module and see what voltage it needs in order to achieve 4 amps. Usually, when I've seen 4 amps being pushed into a low cap module, it's going to swell like crazy or pop the relief every time or both.
    Yours wouldn't be the first charger model to act stupid irt the delta peak voltage cutoff or whatever it's called. Seems to be a semi-common problem with the hobby chargers when used for the hybrid battery modules.
    ozmatt likes this.
  5. ozmatt
    637
    263
    Australia
    Heyslayer thanks for the reply, i gave it a shot with a 5300mah module with "normal" ir and had to terminate the charge manually, watched it start to pull back somewhere around 8.82v :(
    One thing i have noticed is at the start of a charge a note appears on the screen saying "charge to 9v" or similar, surely that does not mean its going to ignore delta and not stop until it reaches a target voltage lol? i have been all through the menu and there is no way to switch that feature off.
    I know some of the cheaper chargers like the imax had issues with delta peak charging on the nimh toyota modules but these toolbox chargers are a slightly better than the imax, better support and somewhat of a following! not premium but not bottom of the barrel either, the hobby guys rate them highly but they are mostly using them for lipos no doubt
  6. Hayslayer
    459
    264
    I don't know that 8.82 v is really a problem at a 4 amp charge rate. Remember, that voltage reading is at the charger itself, so the voltage at the module terminals is going to be a bit lower, even with 14 gauge wire. Glad to see you're using 14ga, and not something crazy small like 18. Small wire creates a lot of ghost headaches for some DIYers. Although I don't use 4 amps for charging, I usually have concerns about the quality of a module when it starts approaching 8.9 volts near the end of charge. If it exceeds 9v, it's usually nfg.
    ozmatt likes this.
  7. ozmatt
    637
    263
    Australia
    Its not a problem just that's where it peaked, I cant remember the exact voltage maybe it was actually 7.92 not .82 I'm not sure.. but either way I watched it peak and start to go backwards so I manually terminated charge it had input about 7700mah and started to swell..
    I plan on charging at 1C and discharging at 2C which is what I have always done and had good success with, I have a purpose built cooling dock that I sit the pack on in the summer time
    I'm sure others here must have tried these chargers by now, they are about 4/ 5 years old and pretty common, just a matter of them noticing the thread and if they feel like chiming in I guess
  8. mr_guy_mann
    mr_guy_mann Senior Member
    4,083
    1,995
    NJ-USA
    I used different chargers back when I did DIY. I recall disabling the delta V setting, and just charged a fixed (7500?) maH amount at 1A. Let the "excess" just turn into heat. 1.5-2A discharge. Took a long time but it seemed to work.
    When the pack had a problem 50k later, I went with a new pack from Toyota.
    ozmatt likes this.
  9. ozmatt
    637
    263
    Australia
    Hi Mr.... I like to charge to delta V at 6.5A that's just what i have always done. I have a purpose built cooling dock with a massive fan inside it so it keeps swelling to a minimum (if delta-v trips) I do also set a cap limit from 7500-8500 depending on estimated condition of the battery im testing but i like to charge at 1c anything less seems like a waste of time literally, and even at 2amps the swelling and heat is near the same but for three times longer therefor im not actually convinced 2a is any less detrimental than 6.5a
    Thing is even at 375ma with a grid charger once you are above 80% the heat still starts to build up, its just what happens i guess
    Has anyone ever noticed how warm the battery can actually be when taken from the car immediately after driving
