Pumping Noise on Standby
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Priuser2016, Nov 3, 2025.
  1. Priuser2016
    Priuser2016 New Member
    Hello, I'm new here, and not a lot of knowledge about cars. I'm looking to confirm what this noise could be?
    After researching I've got it narrowed down to either the Inverter Water Pump or the Coolant Control Valve. Is there any way to tell prior to going to a mechanic?
    Or I could be totally wrong and it's something else entirely since I was searching blindly. I noticed it while stopped at a traffic light. I could hear the faint noise through the front driver side seat, usually kicks in after a few minutes of driving.
    Also if it's either one of those, should I just go to the dealership or will any 3rd party mechanic be able to help out?
    The car is a 2009 Prius with about 193k miles.
    I haven't encountered any error codes yet, and Check Engine Light is OFF. The catalytic converter was replaced about 2 years ago after being stolen so I'm not sure if this is like something that happened because of that?
    Thank you so much!!
    #1 Priuser2016, Nov 3, 2025
  2. ChapmanF
    18,317
    Yes, that washing-machine-agitator noise (or floppy-disk-seeking noise, if you remember those) is the coolant control valve. It's not very complicated to change.
    Priuser2016 likes this.
  3. pasadena_commut
    pasadena_commut Senior Member
    2,700
    806
    Southern California
    Not complicated but mighty inconvenient. Wiggling that odd shaped object out and back in past all the obstacles was a PITA.
    On the positive side - if that valve fails the car still works even though the CEL will be on. On the negative side - it can fail and start leaking coolant through its electrical connector, which cannot be ignored forever. So it is best to fix it.
  4. Priuser2016
    Thank you so much!
  5. Priuser2016
    Thank you. I just got a call back from some auto repair shops, dealer quoted me $1100 for parts and labor, while an auto repair shops that specialize in hybrids estimated $750
  6. pasadena_commut
    2,700
    806
    Southern California
    This is why it pays to fix the small stuff, and this is small stuff, oneself on an older Prius. If one already has the jacks and basic tools fixing this only costs the price of the part and some coolant. Also whatever your time is worth. If one must pay a mechanic's, or heaven forbid, dealer's prices, these little things can add up to a lot of $$$.
