OEM spare tire install
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Hammersmith, May 31, 2023.
  1. VelvetFoot
    VelvetFoot Member
    381
    99
    New York State
    2026 Prius
    Wasn't it upthread where small foam blocks were purchased from a craft store?
  2. mingc
    mingc Junior Member
    25
    Portland, OR
    2023 Prius
    XLE AWD-e
    I tried to read all 500+ posts in this thread but did not see that!
    I've handled the Walmart yoga block and it does look very suitable. It's very firm and very light but has to be cut to the right dimensions.
    #542 mingc, Oct 28, 2025
  3. VelvetFoot
    VelvetFoot Member
    381
    99
    New York State
    2026 Prius
    Ok. I've got nothing else to do....lol.
  4. VelvetFoot
    VelvetFoot Member
    381
    99
    New York State
    2026 Prius
    I misread your post. You have an XLE. I was thinking LE.
    @Humble Bear cut a hole in his LE's foam to fit the tire, but then had to add foam blocks to raise the deck (LE).
    He got small craft blocks from Walmart.
    SPARE TIRE MOD FOR LE FWD model using factory foam | PriusChat
    GcinFl and mingc like this.
  5. VelvetFoot
    VelvetFoot Member
    381
    99
    New York State
    2026 Prius
    The donut fits perfectly behind the passenger seat, with the seat being all the way back.
    I put the tire in a black plastic bag for camouflage purposes. :)
    There are existing cutouts in the foam for the oem factory jack and wrench, and they fit perfect.
    The lower LE deck helps with space. Not sure how a bike will fit in there yet.
    Thanks again to @Hammersmith .
