2008 Toyota Prius would not start without jump. No codes.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by quip1337x, Nov 4, 2025.
  1. quip1337x
    quip1337x New Member
    US
    This has happened twice now. The car will be completely dead requiring a jump start. The second the cables are attached the prius restarts. Checked the 12 V bat and it said "good, needs charging". OBD2 shows no codes. the car was on the second bar of low gas. i dont think i left any lights on. Checked common fuses on right of box. Im not sure if its a low gas problem because after a jump it ran just fine. even restarted. From what i looked up the common issues are inverter water pump or Dc/Dc converter. but both those would pop a OBD code. Checked the hybrid battey and its above the wattage or voltage.
  2. PriusCamper
    PriusCamper Senior Member
    12,736
    5,152
    Pacific Northwest, USA
    My experience is you need to clean and inspect all the connections around the 12v battery. And yes it's normal when there's no 12v power for the Prius to act weird and try to start up partially once it's 12v power is restored and this is easily fixed by turning the vehicle off then back on again the way you normally do.
  3. bisco
    51,897
    how old is your 12 volt. 'good, needs charging' may not tell the whole story. did you charge it?
    what did you test it with?
    PriusCamper likes this.
  4. quip1337x
    US
    i took it to o'rileys and the tester only said "Good, Needs charging." about a 4 year old battery. No I didnt charge the 12V. i sat in the car with the car powered on for 30 minutes as a comment said to online would help the 12v.
  5. BiomedO1
    3,577
    1,854
    SacTown, Ca
    Check battery power at jump point under the hood. You may have a good battery in the trunk, but no power going to the front of the car.
    You still need to perform battery test, to rule that out as the issue.
    You don't have a DC-DC converter issue, otherwise the car wouldn't run - once started. DC-DC converter is same as alternator in a regular car. If it's dead, car wouldn't keep running once you disconnect the jumper cable.
  6. quip1337x
    US
    Could you explain further how to check or what to look for? is the battery test you speak of the same as the first battery test you spoke of?
    are you talking about the hybrid battery because i checked the voltage or wattage and its above the recommended minimum. Thank you for the Dc/dc info. I'm trying to figure out how much this will cost to fix or if its just better to trade it in.
  7. quip1337x
    US
    I went back to O'rileys and the tester when connected to the front jump terminal was showing 12v. i dont know what that means but man said it was good.
  8. PriusCamper
    12,736
    5,152
    You'd need to sit in your car for 12hours to get that battery charged because Prius has a weaksauce DC to DC inverter that's barely able to charge the 12v.
    Not sure why you're acting like you can avoid charging the 12v when the tester said battery needs charging? It's entirely illogical.
  9. quip1337x
    US
    I never acted like anything. My thoughts were if I charge the battery the prius cant cha r ge correctly im just delaying the inevitable. That makes more sense to me than charging it to just die again.
  10. BiomedO1
    3,577
    1,854
    SacTown, Ca
    You need to rule out the 12VDC battery by properly testing it. It could be a battery issue or a parasitic draw on the battery. If you don't have the knowledge, I'd strongly suggest you take it to a professional. Problem solving requires elimination of one known problem at a time. An experienced professional can troubleshoot around minor problems and get to the root cause, very quickly - that's why you pay them $100+/hr.
    Attempting to troubleshooting the problem using Chatgpt or AI is a bit futile, if you don't even have basic knowledge of how the car is suppose to work. You won't even be able to describe the issue properly. You know what they say; garbage-in, garbage-out (very old computer slang).
    As for what O-Riley's parts guy is telling you, I wouldn't hitch my wagon to anything they say is actually factual. I worked in an auto parts store in high school. Training consisted of someone showing someone else how to do things. In most cases they just think they know what they are doing and rely entirely on what the little back box is telling them. I actually grew up in my dad's repair shop, so I knew how those test equipment was suppose to work and why. More than half the equipment wasn't functioning properly, the other half - someone trained people wrong - so wasn't being hooked up properly. You can't complain much, because it's a FREE service; but you need to remember that the store's purpose is to sell you parts.......
    Good Luck.....
  11. PriusCamper
    12,736
    5,152
    Point being a low charge on a 12v battery in a Prius creates all kind of weird electrical anomalies, sometimes even super low MPG, even though the car appears to be functioning normally.
    As in, when I'm working on diagnosing someone's Prius problems or advising someone on how to diagnose their Prius problems the first thing on the list to do is a full and thorough charge of the 12v battery.
    If you decide to disavow that step you're setting yourself up for a way bigger nightmare than you realize...
    And seriously, your Prius won't start and no codes and you think its not relevant to get the 12v fully charged even though that's a known problem in Prius in winter months for cars that are not driven often?
  12. quip1337x
    US
    Do you have any real advice that
    Would you suggest a new battery or to charge it? Thank you for the advice.
  13. PriusCamper
    12,736
    5,152
    Lol...
  14. quip1337x
    US
    I don't know why you cant explain something without being rude Mr Spock. Thank for the advice but the way it sounds to me like you think I'm dumb for not knowing mechanical work. Enjoy your Gate and keeping it.
  15. bisco
    51,897
    at four years, it would probably make sense to replace the battery, unless you already have a charger or want to own one, then it's worth giving it a shot.
    the car will charge the battery, but it takes a long time, depending on the state of discharge, and then you will have to have it tested until it comes back good, fully charged.
    BiomedO1 likes this.
  16. quip1337x
    US
    Thanks everyone but I think this one is solved but didn't want to jump the gun. After I charged the battery it tested badly. So it was the Battery. That makes sense because there was no codes. Thanks again!
    BiomedO1, Brian1954 and bisco like this.
  17. bisco
    51,897
    congrats!
  18. Len Smith
    Len Smith New Member
    Puyallup WA
    My ‘05 prius needed a new 12v battery so i popped one in. When i was installing it i noticed one of the terminal clamps wasn’t snug when i tightened it up, and wouldn’t get any tighter to the post.
    After a couple of weeks the car would fail to start occasionally - with the brand new battery.
    Replaced the old clamp, and no longer have an intermittent starting issue.
  19. BiomedO1
    3,577
    1,854
    SacTown, Ca
    That's why you TEST rather than simply replace. Battery=$200 vs battery clamp=$5; you could've saved yourself $195:rolleyes::oops:o_O:giggle:
    Did you test for parasitic drains?
    #19 BiomedO1, Nov 22, 2025
