Hybrid battery check
Discussion in 'Newbie Forum' started by Daniel dzurnak, Nov 4, 2025.
  1. Daniel dzurnak
    Daniel dzurnak New Member
    West palm
    I understand that there are several ways to check the life of the hybrid battery, but all these idiots at toyota dealers say no??
  2. rjparker
    10,135
    6,298
    Toyota is correct. Others use individual module testing when removed to swap in better used modules in an attempt to keep an old battery going. Usually works for 6 to 18 months when they "may" repair it again.
    Toyota simply looks for a battery fail code. If in warranty the code is necessary to get a warranty replacement. Toyota does not do module replacements.
    A vendor of aftermarket modules created Dr Prius which has a paid feature to extrapolate (guess) the current battery's remaining capacity. Even if the capacity guess is close it does not really tell you how long before it codes.
    Loss of 5 or more mpg is a common indicator your hv battery is weak. Discharging fast at a traffic light causing the engine to restart is another common warning.
