Plane crashes
Discussion in 'Fred's House of Pancakes' started by tochatihu, Nov 5, 2025.
  1. BiomedO1
    3,581
    1,856
    SacTown, Ca
    I understand that; but if that turbine blade disinterested; It would've thrown shrapnel everywhere. Like being shot out of the sky. Again, very old plane and lots of hours on those engines. If the engine fans and air frame wasn't x-rayed for micro-fractures - anything could've gave way. They could've justified, in their own minds, the short-cuts by saying it's a cargo plane, not a passenger plane.
    Unfortunately; I've seen a lot of that too. I'll refuse sign-off, so management will turn to a younger, less experienced person for that sign-off. They become management's favorite and gets promoted. Never seeing consequences for that small short-cut invites more sort cuts and larger bonuses for keeping cost down. It's a vicious cycle. It got so bad, when inspectors were around, management would give me the day off with pay - so I wouldn't 'accidentally' run into an inspector or talk to them. I eventually got out of there, on my own terms - and I knew management wouldn't "bad-mouth" me, because I knew where all the 'bodies' were buried and I knew my way around the database, so I could've dug up even more dirt..
    Boeing already got caught twice, in a decade.
    #21 BiomedO1, Nov 6, 2025
  2. tochatihu
    tochatihu Senior Member
    9,783
    3,768
    Kunming Yunnan China
    2001 Prius
    Engine manufacturer GE may have a hot seat next to UPS' maintenance management team.
    I would reject the idea that cargo planes should maint less. If anyone asked :) They share common airspace and some do take off with a bellyful of jet A.
  3. fuzzy1
    10,440
    Engine casings are designed, and supposed to, contain these blade failures. Not spit them out the side.
    Yes, I'm aware that sometimes it doesn't work.
    This plane had its most recent heavy maintenance, the D-check, last month.
    BiomedO1 likes this.
  4. tochatihu
    9,783
    3,768
    2001 Prius
    Wow, the D-check! That takes 'everything' apart for examining. If any planes have ever augured in a month after D-checks, they must be few in number.
  5. BiomedO1
    3,581
    1,856
    SacTown, Ca
    Oohhhh; anyone who worked on that plane and signed off is going under the microscope.
  6. PriusCamper
    PriusCamper Senior Member
    12,736
    5,152
    Pacific Northwest, USA
    The seat ain't that hot for a cargo plane because you aren't talking about thousands of loved ones grieving over hundreds killed. This is also likely what executive told themselves when the cut corners with their airplane maintenance standards.
    futurist likes this.
  7. fuzzy1
    10,440
  8. ETC(SS)
    7,143
    Looks like the left engine detached before the aircraft cleared the runway, and the plane only 'flew' for a few seconds before they drug a wing through a nearby warehouse and mushed into...........an oil recycling facility!
    Even if the aircraft didn't have a full bag of gas - the resulting fire would have still been a 'crowd pleaser.'
    SDF's location and all those trash haulers flying in and out make me wonder a little bit about things like noise abatement and corporate fuel efficiency 'requests.'
    I fix phones for a living and I'm not even rated to fly armchairs, but I'm thinking that when a bird reaches V1 it is always going to be too fast to be a ground vehicle and too slow to be an aircraft.
    ME??
    I would want V2 to be reeeeeallly close to V1 and as far away from the end of the runway as possible.
    Noise abatement and fuel cost concerns may have been a factor and although the human in the left seat has the authority to override those (limits?) they might be incentivized to lean the other way.
    The MD-11 is 'not' under-powered.
  9. fuzzy1
    10,440
    Some news reports are mentioning similarities between this crash and another crash by the same model in 1979. That would appear to be the AA 191 crash of a DC-10 at O'Hare on May 25, 1979:
    American Airlines Flight 191 - Wikipedia
    ... which is the same event I alluded to yesterday:
    The MD-11 is essentially an updated DC-10. If this turns out to be the same thing, the legal settlements will be very expensive.
  10. tochatihu
    9,783
    3,768
    2001 Prius
    One needs engines for thrust. They can be on wings or empannage at manufacturers' choice. These MDs and many smaller jets have engines aft. Aft placement may not be optimal as separations (if/when they happen) can compromise function of flight control surfaces back yonder..
    More than this aft-engined failure may be required to move engines across the fleet to main wing. If that is even a better design.?
    All jets take about 35 seconds for engines to pull airframes to flying speeds V2. 45 seconds for heavies. During those seconds, pull of engines on airframes is uniquely large. One must plan for that in first design, and assure non failure for entire life of all airframes, That's all I wan na say.
  11. fuzzy1
    10,440
    #31 fuzzy1, Nov 8, 2025
  12. futurist
    futurist Member
    40
    55
    United States
    2024 Prius
    Watching the footage of this crash... holy sheepshite. Reminds of the old late-'70s crash of AA FL191 at O'Hare, that L wing stall and vertical plow with a giant wall of flame. And agree on the uncontained engine failure -- unfort there's a reason old passenger planes tend to become cargo haulers... and since they don't carry anyone but minimal crew... cutting corners w/ maint to keep them in the air working, is a major temptation w/ brinksmanship rewarded... until this happens.
    Fascinated w/ aviation, but have not served in any capacity in it, just as a casual enthusiast watching the reality show of ATC videos (VAS Aviation) on YT at the mo. Had flown small craft like Cubs briefly over water, hopping to the neighbor islands on invitation by the pilot (one of my amazing octogenarian clients who'd retired from Pan Am and kept up his licence flying rentals). How the hell a guy can carry a full conversation with me w/ one hand, his feet and other hand sawing wildy on the controls, landing in the difficult crosswinds at OGG so smoothly, felt like being in a heavy... in a compressible fluid... is boggling to my brain. I had trouble even comprehending the 3-dimensionality of it, whilst performing all your other pilot responsibilities besides 'fly the damned plane' :eek:
    Just feel lucky none of my packages needed to come from the Midwest -- that were a bad one, 12 dead.
  13. Leadfoot J. McCoalroller
    8,077
    7,559
    Pennsylvania
    2018 Prius c
    Last time I rode an MD-11 would have been spring 1997, LAX-CGK with tech stops at HNL & DPS along the way.
    A buddy of mine lost a family member in the Swissair 111 incident which was what turned the tide, all the MD-11s got converted to freighters promptly after that.
  14. Prodigyplace
    12,554
    11,773
    Central Virginia
    The plane there had undergone maintenance months prior and the cause was determined to be due to improper maintenance.
  15. ETC(SS)
    7,143
    A formal preliminary report from the NTSB will probably be released about +30 days. CVR deets have already been widely reported - perhaps accurately.
    An alarm began about 37 seconds after the crew cracked open the throttles and continued until the end of the recording about 25 seconds later. The aircraft reportedly reached 100' of altitude but the bird was 200 feel long and the altitude sensors are probably in the forward half of the aircraft.
    Death toll is now 14.
    MD-11s are now grounded and I anticipate some if not most of them will be sold if not scrapped - a process that was already underway.
    UPS had 40 something hulls in service - now in the mid 20s.
    That's a lot of lift capacity for Santa, and it's a quarter past November....so we will see what we see.
    futurist and Prodigyplace like this.
  16. fuzzy1
    10,440
    ... as I already stated there.
    Prodigyplace likes this.
  17. ETC(SS)
    7,143
    Props to whomever stated that the #1 engine trashed the #3 engine.
    I was skeptical of this given engine locations but it appears I easily could have been wrong about that.
    I discounted this as a likelihood since they were on the wings.......buuuuuut that's why you WAIT until +30 to pontificate.
    Evidence of a right-side compressor stall is now being revealed, and if this turns out to be the case, it points well away from a crew issue....IMHO.
    It fits - and explains why they never slipped the surly bonds with 2/3 of their engines straining at the mounts.....which is WHY we give things like this a '30-count.' ;)
  18. bwilson4web
    16,204
    Here is a better technical description of what probably happened:
  19. ETC(SS)
    7,143
    Pylon issues are indeed not unheard of in this type.
    (These types?)
    I figured - probably incorrectly, that when #1engine left the scene that the aircraft should clear the fence with 'just' a fire on the wing and with a moderate decrease in thrust and some control issues.
    And remember......they DID clear the fence.
    If #3 was impacted?
    They never had a chance beyond that.
    I was a little concerned that they were incentivised to NOT use all of the runway and all of the throttle, but these concerns may also have been unfounded.
    Now that I think about it, throttles are like neighborhood bars.
    It REALLY DOES pay to "go ugly, early."
    #39 ETC(SS), Nov 10, 2025
  20. ColoradoBoo
    ColoradoBoo Senior Member
    1,240
    827
    Monument, Colorado USA
