Wheel and Tire fitment and TPMS questions
Discussion in 'Gen 5 Prius Main Forum' started by kev604, Nov 6, 2025.
  1. kev604
    kev604 Junior Member
    56
    49
    Vancouver, BC Canada
    2026 Prius Plug-in
    New owner here of a 2026 XSE Premium PHEV so I apologize if some of my questions have been asked and answered.
    First off can someone confirm the wheel specs for the 19s are 19x6.5 +40 offset and 17s are 17x6.5 +40 offset?
    The 19s on the Prius as we all know with those oddball wheel specs tire options are very limited. The few AS tires offered in 195/50/19 are pretty trash although Michelin does make the X-Ice Snows in this size. I've had experience with the X-Ice Snows and they are excellent tires and well suited for my driving environment so if I mount X-ICE Snows on the 19s I'll need a second set of wheels.
    For a second set of wheels I'd be looking at a slightly wider wheel in 18s or 17s so I have more tire options. If I go wider wheels and tires I am concerned about strut clearance does anyone know how much strut clearance I have over the stock spec wheels if I go wider? Again I'm not out to slam it or turn it in to a race car just looking for more tire options if possible.
    I've also been researching the TPMS. Am I able to buy TPMS at the tire shop and clone them to the car? I know I did that with my wife's old.Nissan and that worked flawlessly.
    TIA
  2. Tideland Prius
    16,615
    otatrant likes this.
  3. reservoirblue
    reservoirblue Member
    96
    76
    Woodacre, CA
    2024 Prius Prime
    SE
    Just search tire options here on this site. I've had 215-55-17 on the original rims for a while.
    Tekz likes this.
  4. kev604
    56
    49
    2026 Prius Plug-in
    My wheels are 19s so there aren't narrow tire options available on 19s.A 215/45/19 tire for example doesn't exist. I like the stock wheels but the OEM Toyo's are sub par so looks like the only way to upgrade my tires would be to invest in new wheels and mount snow tires on the OEM wheels.
  5. kev604
    56
    49
    2026 Prius Plug-in
    Offset?
    A 17x7.5 wheel with say a +40 offset the wheel would then sit 13mm closer to the strut and poke out 13mm further than stock. Without actually trying I'm guessing something like this will fit but you'll have to size your tire carefully probably a 215 wide tire on the safe side a 225 wide tire would be wise to test out first
  6. Tideland Prius
    16,615
    All the specs are in that link.
    I think 215 should be ok. 225 is likely pushing it.
    Tekz and frodoz737 like this.
  7. Hammersmith
    Hammersmith Senior Member
    2,315
    2,363
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Just putting it out there again that Michelin should be selling the CrossClimate 3 here next year in 205/50-19 which will work on the OEM wheels. It's currently being rolled out in Europe.
    Just throwing it out there as an option for those considering considering new wheels just to get better tire options.
    GeoJ and Tideland Prius like this.
  8. kev604
    56
    49
    2026 Prius Plug-in
    That's good to know and will benefit a lot of people. I've always been a dedicated snow tire guy and run two sets of tires and will probably do the same on the Prius.
    frodoz737 likes this.
  9. kev604
    56
    49
    2026 Prius Plug-in
    What tire pressure are you guys running on OEM tires and aftermarket/winter tires? When I first checked I was surprised to see a staggered tire pressure set up for the OEM 19 inch tires.The dealer loaded all 4 tires to 35 PSI so I dropped the tears back to 33 PSI per spec but I might bump the rears back to 35 all around.
  10. Hammersmith
    2,315
    2,363
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I typically run +2psi. So 37/35. Others run significantly more. I try to strike a balance between a little more efficiency without making the ride too rough. I'd probably drop back to stock if I expected really bad winter weather, but I'm too lazy to actually do it.
  11. kev604
    56
    49
    2026 Prius Plug-in
    Is there a reason you know for the staggered tire pressure setup? I do find 33 PSI a bit low probably will run 35 PSI all around. I'm planning to mount 215/55/17 snow tires next week will run 36 PSI on the taller tires.
  12. Hammersmith
    2,315
    2,363
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Don't know the reason for it, but I figure Toyota does.
  13. kev604
    56
    49
    2026 Prius Plug-in
    So I've made an appointment on Tuesday to mount snow tires. Here is what I've got. A set of 5x114.3 alloys and tires off my previous car. Wheel specs are 17x7 +45 with 215/55/17 Michelin X Ice Shows. Got some 73.1-60.1 hubcentric rings ready to go. Spoke to the tire shop and will be purchasing a set of new sensors from them which they will clone to the car. The stock wheel specs versus new wheel specs the new wheel will sit 11mm further in and 1mm further out, overall diameter is -10mm, overall ride height is -5mm and speed error is +1.5%. I don't foresee any fitment issues.
    I also have a set of wheels spec 17x7.5 +38 which I think would actually fit better that I could use but just going to keep it simple for now and use the wheels and tires already mounted.
  14. kev604
    56
    49
    2026 Prius Plug-in
    Got the wheels all loaded up nicely and ready to go. Went to my trusted tire shop and the first thing he.asked me if it was a 2026 and if it was than their software would not be able to clone the TPMS sensors because their software isn't updated to 2026 models. So ended up buying OEM sensors from Toyota and have an appointment this week with Toyota to install the sensors on my wheels and program them to the car. What a headache to mount snow tires hopefully no more surprises.
  15. mingc
    mingc Member
    77
    58
    Portland, OR
    2023 Prius
    XLE AWD-e
    Michelin USA's website indicates that the CrossClimate 3 isn't coming to North America anytime soon and that it will continue to sell the CrossClimate 2 "for the next several years":
    MICHELIN CROSSCLIMATE 2 - Vehicle Tires | Michelin USA (scroll down to the last FAQ on the page)
    Do you have other, more hopeful, information?
  16. Hammersmith
    2,315
    2,363
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Well, crap. Didn't see that(or it's a fairly new addition).
    mingc likes this.
  17. Mendel Leisk
    41,900
    I've a couple of steadfast rules when scoring tires now:
    1. Take the valve caps off the old tires (Hey, a small stab at conservation)
    2. With directional tires (Michelin Snows for example), tell them not to wrap the new ones, and if they do pull it off and check the directional arrows, BEFORE driving off. (Looking at the outside faces, you should be seeing two clockwise, and two counterclockwise. Costco's tire shop, in my experience, has screwed it up, both times I bought from them.)
    Tande likes this.
  18. kev604
    56
    49
    2026 Prius Plug-in
    Okay got the wheels and new OEM sensors mounted yesterday with no issues. Sensors were installed and programed to the TPMS by the dealer. I did not have to drive around for them to reset, when I started the car it was ready to go which was a pleasant surprise.
    Hope you guys like bronze. Wheels are Sparco Assetto Gara 17x7 +45 and tires are 215/55/17 Michelin X-Ice Snows. Happy to report no fitment issues.
  19. VelvetFoot
    VelvetFoot Active Member
    1,212
    473
    New York State
    2026 Prius
  20. kev604
    56
    49
    2026 Prius Plug-in
    I wasn't sure I was going to like the looks of the 17s on the Prius but now that I have them on the car I got to say I like it. Looks good and I've always been a fan of meaty tires. Now I'm thinking when the OEM tires wear down I may switch to 17s year round and have way more tire options.
