OEM vs Aftermarket Fender Liner, Passenge
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gatorback, Nov 7, 2025 at 10:31 AM.
  1. gatorback
    gatorback New Member
    Is there any consensus as to whether it is worth using the OEM OEM 53875-47030?
    TL/DR: OEM is at least twice they cost: chatgpt found an OEM at $72.
    If you have experience replacing this part, please advise if you bought OEM and if you did its yourself + any lessons learned. Thank you.
    Ref: ChatGPT - Toyota Prius part number
    #1 gatorback, Nov 7, 2025 at 10:31 AM
  2. Tombukt2
    12,848
    2,308
    I use the softer aftermarket units tend to not crack like the hi styrene factory . Make sure to get the meatal dog bone inserts for front lil air dams
  3. gatorback
    Thanks for the reply: Please clarify with a photo or a link to purchase the metal dog bone inserts? Is there a purchase link with a description photo?
    There seems to be a lot of variations in the aftermarket products. If you are happy with yours, can you provide me with a link or supplier / part number?
  4. PriusCamper
    PriusCamper Senior Member
    12,617
    5,098
    Pacific Northwest, USA
    I've installed both OEM and aftermarket and have noticed no significant difference other than price.
  5. Brian1954
    Brian1954 Senior Member
    2,094
    813
    South Central PA, USA
    I replaced the front left fender liner in August 2024 with a generic one bought on Amazon for $28. It took a while to install correctly, but it has worked fine.
