Featured Reminder for drivers in the Northern Hemisphere
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Leadfoot J. McCoalroller, Nov 7, 2025.
  1. Leadfoot J. McCoalroller
    8,077
    7,559
    Pennsylvania
    2018 Prius c
    Temperatures are dropping!
    This weekend is a good time to check your tire pressure and top it up.
    With lower temps you may be a few pounds low- maybe not enough to trip the TPMS (if any) but you can still lose fuel economy before that tire light comes on.
  2. PriusCamper
    PriusCamper Senior Member
    12,736
    5,152
    Pacific Northwest, USA
    I'll also suggest basing your tire pressure needs on the roads you drive on rather then what the tire maker's lawyers decide to stamp on all the tires. As in add a couple few pounds of air at a time and then on a rainy day if your tires slip a little accelerating hard away from a stoplight you know to lower tire pressure a little to improve traction. And as always, because the engine is in the front you'll want a couple pounds more in the front than in the rear. In winter for me that works out to about 45psi in front and 43psi in the rears and higher than that in the Summer.
    Isaac Zachary likes this.
  3. Leadfoot J. McCoalroller
    8,077
    7,559
    Pennsylvania
    2018 Prius c
    Saturday bump- all 8 tires in my family fleet needed a few pounds each, how did you do?
  4. ChapmanF
    18,154
    About the same.
  5. Isaac Zachary
    Isaac Zachary Senior Member
    2,545
    1,286
    And check tread depth. 3/16 of an inch minimum here in Colorado.
    Also check tire rating. Must have either a M+S symbol or a three-peak-snowflake symbol, or both. (Unless it's an AWD or 4WD, in which case in Colorado you can legally drive around on summer tires, something that I do not agree with).
  6. fuzzy1
    10,439
    Similar here several weeks ago, will need another check soon as temperatures continue to drop.
  7. bisco
    51,899
    i'm right at the lawyers recommendation. if i wasn't so lazy, i'd go put a few pounds in.
    on the plus side, i'm getting a much softer ride than usual
    PriusCamper likes this.
  8. mikefocke
    3,994
    1,804
    Sanford, NC
    AC on today, 18F on Tuesday morning. Trees dropping leaves like mad. I rake daily...well actually I blow into a pile and mulch them with a power mower and then dump a bag into bare spots in the wooded back yard.
  9. bisco
    51,899
    that's one way to pump up your tyres!
  10. Tideland Prius
    16,555
    Yup, mine were 2 psi under.
    Also, if you live in a multiplex with underground garage, adjust for the outside temperature because your garage maybe 15°C or even 20°C so if you pump to manufacturer spec, you're actually underinflated once you're outside.
  11. Gorgonzola
    Gorgonzola Junior Member
    34
    New Hampshire, USA
    2024 Prius
    LE AWD-e
    I think this thread applies to drivers in all colder climates, not just New Hampshire…
  12. Leadfoot J. McCoalroller
    8,077
    7,559
    Pennsylvania
    2018 Prius c
    No argument there, I just try to make an annual reminder when it's getting cooler in the USA & Canada since that's where a preponderence of PriusChat readers live.
    Each year I try to pick a weekend when it really is getting colder (worth doing) but not so cold that nobody wants to go outside and deal with it.
    Gorgonzola likes this.
  13. bwilson4web
    16,204
    Unfortunately, I also included annual vaccination notice and an Anti-VAXer spent a lot of electrons railing against them. Upon a gentle suggestion that I might have provoked the response, I gave a practical provocation example another thread: Vaccine provocation | PriusChat
  14. Gorgonzola
    34
    New Hampshire, USA
    2024 Prius
    LE AWD-e
    My goodness, I realize now that I completely misread the title of this thread. Instead of “Northern Hemisphere,” I thought it said “Northern New Hampshire…” and that struck me as awfully specific! Ha! Forgive my hastiness
