12v battery question
Discussion in 'Gen 3 Prius Main Forum' started by Docdkay, Aug 29, 2021.
Tags:
  1. ChapmanF
    17,980
    I suspect it's really doing a CA test, unless you have a 0 ℉ freezer to keep the battery in for a while before testing, or you make sure to use it on winter days that happen to be 0 ℉, which would match an official CCA test.
    Or maybe the reduction in CA with decreasing temperature has a known formula, and the tester measures the ambient temperature and corrects it to 0 ℉ with math. I don't know if that's practical.
  2. Mendel Leisk
    41,196
    It has several other options, including CA (Crsnking Amps) though I’m not sure my battery specs that. Would there be a general factor applicable to CCA that would ballpark the CA?
    that said, testers of that ilk typically offer CCA measurement; they employ some method to make measurements at other than zero?
  3. priumium
    priumium Member
    100
    25
    Sweden
    I wonder why you care about crank amps for a Prius? The 12V does not crank anything, it just powers up the ECU…
    Yuasa is the best I have tried, but I also use ctek attachment and recond them 12V every quarter year regardless. Dead aux batteries are the worst.
  4. ChapmanF
    17,980
    That's not the first time that's been wondered in this thread. Seems like every time it gets wondered, someone has to say again "because there are common tools that let you compare a battery's present cranking amps to the cranking amps on its label, and that's an easy way to get an indication of the battery's present condition".
    Doesn't need to have anything to do with 'cranking' needs of the car.
  5. johnHRP
    johnHRP Active Member
    642
    185
    KA, DE
    Excel
    Autozone and Advanced Auto do battery test for free
  6. priumium
    priumium Member
    100
    25
    Sweden
    Agreed, but then I also have to wonder what do a Prius actually need in A (sustainable for five seconds?) to boot the system?
    (CA value is defined on need to be able to (repeatedly) crank an engine. That is a highly irrelevant value for the Prius.)
    #26 priumium, Nov 7, 2025 at 7:43 AM
  7. priumium
    priumium Member
    100
    25
    Sweden
    The banal ballpark test for any battery sustainability/capacity - apart from for Prius irrelevant CA - may be to know the exact A input charge, then measure the amount of time in H it takes to get that battery to full - if initially almost empty.
    It’s fairly obvious if a ie 45Ah battery charges very fast (under 2 hours on 5A charge) from empty/low, it’s a loss/toss. Even CTEK can’t fix those and it will not hold for any kind of weeks.
    #27 priumium, Nov 7, 2025 at 7:46 AM
  8. ChapmanF
    17,980
    That same condition may also show up quickly on the local auto shop's CA tester, as a value much lower than what's on the label, and that's a convenient test you don't have to wait 2 hours for.
    As far as I know, that's the only reason PriusChat people give for caring what CA your battery's label says. Even the lowest commercially-available car battery CA ratings are several times what it takes to make a Prius READY.
    There are threads in this forum where graphs of amp draw during the few seconds of going READY have been posted. I seem to remember the area under the graph being about 90 amp seconds, over a stretch of 2 or 3 seconds, so an average of 30 amps or so, but the graph is more spiky than steady.
    priumium likes this.
  9. priumium
    priumium Member
    100
    25
    Sweden
    AI answer; The 12V battery only requires about 30 amps (per what tempus?) to turn on the computers, which then allows the high-voltage battery to start the car.
  10. ChapmanF
    17,980
    Proof once again that AI chatbots are getting almost good enough to describe a simple graph.
  11. Prodigyplace
    12,511
    11,736
    Central Virginia
    The 12V battery does not power the high voltage relays? That's news to me.
  12. Prodigyplace
    12,511
    11,736
    Central Virginia
    If the battery does not use its power to close the high voltage relays, just powering the ECUs is a moot point.
  13. ChapmanF
    17,980
    I don't think that 'news' was entailed by anything the quoted poster wrote.
    Yes, for the second or so before the car makes READY, the 12-volt battery powers all of the 12-volt equipment that happens to be turned on. The dash instruments, the ACC and P/POINT relays, the three IG1 relays, the IG2 and EFI and IGCT relays, the brake and power steering systems, and all the ECUs. When the power management control ECU completes its checklist and judges the car safe to go READY, that ECU then powers the three relays in the battery in their proper sequence.
    I've never understood why so many posts seem to fixate on it powers the high-voltage relays! as if it were somehow the main thing the 12-volt battery was doing. The total draw of all the relays I've just mentioned is probably less than the dome lights.
