Dealer Only Customizable Features/Carista
Discussion in 'Gen 5 Prius Main Forum' started by VelvetFoot, Nov 5, 2025.
  1. AzusaPrius
    AzusaPrius Senior Member
    2,232
    930
    Yes you have to buy the Carista OBD adapter, but it works with every other OBD app out there, so you can use it with an app like Dr. Prius or Torque also.
  2. otatrant
    otatrant Active Member
    348
    211
    San Francisco
    2023 Prius Prime
    XSE Premium
    Here is a link to compatible third party scanners from the Carista help site.
    VelvetFoot likes this.
  3. mannymendez25
    mannymendez25 Member
    67
    Miami
    2020 Prius
    I went to my local Toyota for an oil change and asked them to enable the window roll down feature with the remote. They gave me some mumbo gumbo response stating I had to pay for that. They told me it was a long process, they had to download a software update from Toyota to enable that, yada, yada, yada. I plugged in my ODB2 adapter and enabled it within a few seconds using Carista. The dealer tried to F me but I got the last laugh.
    otatrant likes this.
  4. VelvetFoot
    VelvetFoot Active Member
    1,209
    472
    New York State
    2026 Prius
    Thanks very much. I actually looked, believe it or not, but not hard enough! :)
  5. VelvetFoot
    1,209
    472
    New York State
    2026 Prius
    Was window rollup an option as well?
  6. VelvetFoot
    1,209
    472
    New York State
    2026 Prius
    I think I recall a dealer of another brand giving me one 'free' option programming.
    If you changed your mind, you'd pay through the nose.
  7. otatrant
    348
    211
    San Francisco
    2023 Prius Prime
    XSE Premium
    I can confirm that VXDiag VCX PLUS works with my 2023 Prius Prime. Comes with Techstream 18. Only setting I have changed is the length of time the odometer displays after you shut off the car. The odometer setting seems to have persisted in the settings but I haven't driven since I changed it. Need a windows PC to run Techstream 18, install the drivers and you may have to use the profile for the 2023 Prius which I believe will work for all 5th Generation Prii. Pretty straightforward. You can download their installation files online.
    4 models in the VXDiag VCX series. The middle 2 seem to be the sweet spot for the Prius with DoIP which means it should be able to talk with Techstream. I have not tried this yet. The cheapest VCX Nano which will not connect to Techstream is ~$130, the next cheapest is the VCX Nano which should be able to connect to Techstream but comes in plastic housing is ~$190, the one I purchased VCX Plus 4 in 1 is ~ $315 plus I believe I had to pay some extra tariff maybe like $30 to get it through customs is in an Aluminum case and is more rugged in durable. The most expensive one in the series is overkill for the Prius since it has coverage for several standards that are not compatible with Toyota OBD.
    I have only had mine for less than a week but so far I have been impressed especially when you consider the price. Here is a link to the product comparison page.
    Here is a screenshot of a summary comparison between models.
  8. otatrant
    348
    211
    San Francisco
    2023 Prius Prime
    XSE Premium
  9. longshot
    longshot Junior Member
    84
    Pretty sure you can use a 3rd party OBD like the BT ELM327 long as it has 1.4 up on it
