OEM vs Aftermarket Fender Liner, Passenge
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gatorback, Nov 7, 2025 at 10:31 AM.
  1. gatorback
    gatorback New Member
    Is there any consensus as to whether it is worth using the OEM OEM 53875-47030?
    TL/DR: OEM is at least twice they cost: chatgpt found an OEM at $72.
    If you have experience replacing this part, please advise if you bought OEM and if you did its yourself + any lessons learned. Thank you.
    Ref: ChatGPT - Toyota Prius part number
    #1 gatorback, Nov 7, 2025 at 10:31 AM
  2. Tombukt2
    12,851
    2,312
    I use the softer aftermarket units tend to not crack like the hi styrene factory . Make sure to get the meatal dog bone inserts for front lil air dams
  3. gatorback
    Thanks for the reply: Please clarify with a photo or a link to purchase the metal dog bone inserts? Is there a purchase link with a description photo?
    There seems to be a lot of variations in the aftermarket products. If you are happy with yours, can you provide me with a link or supplier / part number?
  4. PriusCamper
    PriusCamper Senior Member
    12,620
    5,103
    Pacific Northwest, USA
    I've installed both OEM and aftermarket and have noticed no significant difference other than price.
    gatorback likes this.
  5. Brian1954
    Brian1954 Senior Member
    2,098
    814
    South Central PA, USA
    I replaced the front left fender liner in August 2024 with a generic one bought on Amazon for $28. It took a while to install correctly, but it has worked fine.
  6. gatorback
    I was shopping Amazon and notice many options. Would you mind providing the link to the one you purchased and any other accessories? Thank you
  7. Mendel Leisk
    41,199
    I found pulling those liners out (for cleaning behind), there's one fastener at the back, in the middle, that apparently impossible to remove without destroying. Fuzzy on the details, but you'll find it.
    Also, there's metal bar with square head "bolts", clamping the arched wheel well portion's leading end to the flat bottom panel at the front. After a year or two those bolts become solid rust lumps, don't bother attempting to disassemble that joint.
  8. Brian1954
    2,098
    814
    I bought parts for the front left on Amazon. Linked below are the two parts I purchased.
    Parts N Go Prius Front Fender Liner Left Driver Side LH Splash Guard 2010-2015 - TO1248158, 53876-47030, 53876-47070
    Genuine Toyota 53852-47020 Wheel Opening Pad
    I reused the fastener that were not broken and replaced the push type pins that were broken with these,
    GOOACC 100PCS 6.5mm 7mm 9mm Compatible with Toyota Push Type Retainer 90467-10183,Engine Under Cover Push-Type Retainer for Lexus&Toyota Clips 90467-07201,for Toyota 52161-02020 Bonus Fastener Remover
