Winter tire pressures
Discussion in 'Gen 5 Prius Main Forum' started by Paul Gregory, Nov 9, 2025.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,263
    603
    Alberta
    2024 Prius Prime
    XSE
    Whenever temps drop to around freezing, my tire pressure alert light comes on. It eventually turns off after a period of driving, as the tires warm up. I prefer to add a bit more pressure, just to keep the light from coming on. Not quite such good traction, but I can manage.
  2. VelvetFoot
    VelvetFoot Senior Member
    1,320
    513
    New York State
    2026 Prius
    Tire pressures drop when it gets cold. Why not turn on the gauge and look at what pressure the tires are at?
  3. Mendel Leisk
    42,038
    The TPMS light supposedly don't go on until one or more of the tires drops to about 25% below the last set pressure. If you've not reset it I would suspect that set pressure would have been set at the factory, per the door jamb decal, maybe the higher value, if there's two (front vs rear). Periodic check with a pressure gauge will catch pressure drops sooner.
    Fifth gen can display the pressures? That's good.
  4. Paul Gregory
    2,263
    603
    Alberta
    2024 Prius Prime
    XSE
    They either show a few psi below normal, or they say "adjust tire pressure."
  5. ChapmanF
    18,685
    The TPMS is able to have a different alert threshold for each transmitter, so they could be programmed from the factory for both the front and rear placard pressures. (Of course, the first tire rotation messes that up unless you then reset the thresholds, because they're remembered per transmitter, not per position on the car.)
    Personally, I dislike how low the default alert thresholds are. You don't get to set them directly: you air the tires to the pressure you want, and use the SET button, and alert thresholds get set at some % below the current reading. When SET at mid-30s (psi) pressures, the alert thresholds were ending up in the 20s.
    I want to know about low tires sooner than that, so what I've ended up doing is just airing the tires to the max sidewall number, pressing SET, and then letting them back down to the pressures I want.
    That leaves the alert thresholds set just a few psi below my preferred pressures. Which is what I want.
    Though it does mean I can't help noticing the way pressure changes with temperature, as my light will come on with any modest cold snap, until I add some air as needed.
    One thing I don't religiously do is check for higher pressures than I prefer when the weather warms up. The TPMS doesn't offer high-alert thresholds (unless that's new in later generations than mine). So I just usually end up driving on harder tires for a while if the weather has recently warmed a lot.
    Mendel Leisk and fuzzy1 like this.
  6. VelvetFoot
    1,320
    513
    New York State
    2026 Prius
    #6 VelvetFoot, Nov 9, 2025
  7. PriusCamper
    PriusCamper Senior Member
    13,180
    5,333
    Pacific Northwest, USA
    You tire pressure is too low.
  8. bisco
    52,517
    what is more important, cold pressure or after you've been driving a bit?
  9. VelvetFoot
    1,320
    513
    New York State
    2026 Prius
    In other news...how 'bout those miles on my first tank? :)
  10. bisco
    52,517
    nice, i used to get 60mpg in my '04!
    VelvetFoot likes this.
  11. fuzzy1
    10,603
    The tire labeling and door placard figures are all referenced back to cold pressure.
    Brian1954, Mendel Leisk and bisco like this.
  12. ChapmanF
    18,685
    The pressures on the placard are cold pressures. Pressures after driving will be higher; that's taken into account when deciding what the cold pressures on the placard should be.
    fuzzy1 and bisco like this.
  13. bisco
    52,517
    i thank y'all
  14. Paul Gregory
    2,263
    603
    Alberta
    2024 Prius Prime
    XSE
    Mine comes on long before a 25% loss of tire pressure.
    Seems more like 10%.
  15. Mendel Leisk
    42,038
    Could be gen 5 revision. Interesting too, that it now displays all four tire pressures, much more informative.
  16. bisco
    52,517
    i start mine high. haven'r touched them in 2 years, and they are still at door sticker recs
  17. Mendel Leisk
    42,038
    If you air up at a gas station with warmed up tires, good ploy is to put about 4 extra psi in, check and bleed them off as needed later, when cold.
  18. VelvetFoot
    1,320
    513
    New York State
    2026 Prius
    On your first tank? :)
  19. bisco
    52,517
    oh ya, that thing was a beast from the get go. but i drive like my granny, have since i survived teen age years
  20. VelvetFoot
    1,320
    513
    New York State
    2026 Prius
    I probably have to learn some Hybrid techniques, lol.
