Cruise control gen 4
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Skitchin1, Nov 8, 2025.
  1. Skitchin1
    Skitchin1 New Member
    Michigan
    Hi my cruise control don't work. I turn it on show the icon on center display. I toggle down to set cruise control and noting happens. Not sure what to problem could be. Try googling fuses but there not answer what one controls cruise control.
    52,351
    if it's acc, it might be a dirty sensor
  3. Skitchin1
    Michigan
    Right if so got to figure out what sensor. But figured I would check the fuse first.
    Bought the car used. Tryed cruise and it like the feedback from the cruise knob other then the on and off don't work. Just when I try to Google what fuse controls the cruise control it list 3 to 5 fuses and most are ecu fuses.
  4. Skitchin1
    Michigan
    I figured it out. It has to be in D and not B.
    And front emblem got to be clear of snow or else it won't shut up about clean front sensor.
