2008 Prius car does not start when putting the key in the key slot or keyless start. The only way it can start is putting the key under the steering wheel. This all started when the car died and have to jump started
That's interesting because the amplifier and antenna are built into the key slot I believe . The label on the bottom of the key slot denotes amplifier and a part number so now you're key under wheel . Nothing really down they're . I'd literally have to take my fob scanner and run it around the steer wheels amplifier etc and see what's pushing a signal . Really strange . I'm not sure how many antennae there are . And nothing's happened to fob . You only have 1?
very strange. i would replace the fob battery with a new duracell, and get a free load test on the 12 volt at most auto parts stores. do you have a second fob?
Is this the same car that you created a thread about on October 16th? https://priuschat.com/index.php?posts/3572243
Yes we jumped and we drove it to charge up the battery and it starts up every-time without jumping it.
Did the same key previously work when you put it into the slot? Maybe the chip is missing inside the fob.
the key works without putting it in the slot when it jump started and went for a drive and then when i turn it off it don't work no more. I tried with my second key and doing the same thing.
