OEM vs Aftermarket Fender Liner, Passenge
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gatorback, Nov 7, 2025.
  1. gatorback
    gatorback Junior Member
    58
    Is there any consensus as to whether it is worth using the OEM OEM 53875-47030?
    TL/DR: OEM is at least twice they cost: chatgpt found an OEM at $72.
    If you have experience replacing this part, please advise if you bought OEM and if you did its yourself + any lessons learned. Thank you.
    Ref: ChatGPT - Toyota Prius part number
    #1 gatorback, Nov 7, 2025
  2. Tombukt2
    13,484
    2,425
    I use the softer aftermarket units tend to not crack like the hi styrene factory . Make sure to get the meatal dog bone inserts for front lil air dams
  3. gatorback
    58
    Thanks for the reply: Please clarify with a photo or a link to purchase the metal dog bone inserts? Is there a purchase link with a description photo?
    There seems to be a lot of variations in the aftermarket products. If you are happy with yours, can you provide me with a link or supplier / part number?
  4. PriusCamper
    PriusCamper Senior Member
    13,104
    5,312
    Pacific Northwest, USA
    I've installed both OEM and aftermarket and have noticed no significant difference other than price.
    gatorback likes this.
  5. Brian1954
    Brian1954 Senior Member
    2,422
    972
    South Central PA, USA
    I replaced the front left fender liner in August 2024 with a generic one bought on Amazon for $28. It took a while to install correctly, but it has worked fine.
  6. gatorback
    58
    I was shopping Amazon and notice many options. Would you mind providing the link to the one you purchased and any other accessories? Thank you
  7. Mendel Leisk
    41,951
    I found pulling those liners out (for cleaning behind), there's one fastener at the back, in the middle, that apparently impossible to remove without destroying. Fuzzy on the details, but you'll find it.
    Also, there's metal bar with square head "bolts", clamping the arched wheel well portion's leading end to the flat bottom panel at the front. After a year or two those bolts become solid rust lumps, don't bother attempting to disassemble that joint.
  8. Brian1954
    2,422
    972
    I bought parts for the front left on Amazon. Linked below are the two parts I purchased.
    Parts N Go Prius Front Fender Liner Left Driver Side LH Splash Guard 2010-2015 - TO1248158, 53876-47030, 53876-47070
    Genuine Toyota 53852-47020 Wheel Opening Pad
    I reused the fastener that were not broken and replaced the push type pins that were broken with these,
    GOOACC 100PCS 6.5mm 7mm 9mm Compatible with Toyota Push Type Retainer 90467-10183,Engine Under Cover Push-Type Retainer for Lexus&Toyota Clips 90467-07201,for Toyota 52161-02020 Bonus Fastener Remover
  9. themzlab
    themzlab Junior Member
    28
    Wisconsin USA
    I initially bought some cheap ones from Ebay and then noticed they did not match the OEM design. I tossed those and eventually found CAPA certified replacements from carparts.com. This is what I put in just yesterday. These are made in Taiwan and closely match the original parts. I bought stainless bolts and cap nuts to re-install the little aero dam on the bottom of the liner.
    I also bought OEM push nuts and new screws. I found that using the original rusted screws doesn't work because the friction is too high and the plastic nuts will turn in circles instead of tightening down. There is a balance required for that system to work and it does best with fresh parts.
    gatorback and Brian1954 like this.
  10. gatorback
    58
    Thanks for the links! I am trying to figure out what the "Wheel Opening Pad" is for and if I need to buy one. What is said item and what is its purpose?
  11. Brian1954
    2,422
    972
    The "Wheel Opening Pad" part is located on the bottom in front of the wheel well. It sticks down and I believe it bridges between the fender liner and the plastic undercarriage piece. I took a picture of the left front of my 2011 Prius to show you the location. Front Left Wheel Undercarriage.jpg
    Just compare the left and right sides of your car to determine what parts are missing from your right side.
    #11 Brian1954, Nov 10, 2025
  12. Brian1954
    2,422
    972
    Here is another picture from a different angle. 53852-47020 Wheel Opening Pad .jpg
  13. gatorback
    58
    I just installed said part / bridge. Good video showing disassembly / removal of the bridge ("pad"):
