2015 Prius V 3 Trouble Codes
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by AZaly, Nov 9, 2025 at 10:17 PM.
  1. AZaly
    AZaly New Member
    Sunday
    Battle Ground, WA
    2015 Prius v wagon
    Could these codes indicate the ignition coils and spark plugs need to be changed or is there additional repairs needed.
    See photo attached.
  2. Brian1954
    Brian1954 Senior Member
    2,118
    818
    South Central PA, USA
    Those are historical codes. They are not current or active codes. There is nothing to worry about unless they are current codes.
    How many miles on the car?
    BiomedO1 likes this.
  3. BiomedO1
    3,425
    1,784
    SacTown, Ca
    Yep; It could've happen with a loose gas cap on the emission control code.
    The cylinder #2 misfire may indicate something - check your engine coolant level (passenger side reservoir).
  4. AZaly
    AZaly New Member
    Sunday
    Battle Ground, WA
    2015 Prius v wagon
    I cleared the codes the 1st time and the 2nd time I scanned it, they reappeared.
    When the engine starts it begins to rough idle until you turn it off.
    The gas cap is tightened.
    It has 245k miles.
  5. Brian1954
    2,118
    818
    Please provide a little history about the car. Has the head gasket or engine been replaced?
