Dash Lights Brake, !, abs. vsc, srs all on but no codes?
Discussion in 'Gen 2 Prius Main Forum' started by 2genowner, Nov 11, 2025.
  1. 2genowner
    2genowner New Member
    Rhode Island
    all the above mentioned Lights are on and cant seem to find out why or reset them
    Tried a couple mentioned items like go into Diagnose mode And can get into that mode but does not seem to be anything to reset. Replaced 12 v battery already as it was getting weak 20251106_110532.jpg
    Any other ideas on what to try next. I think it all started when the 12 v battery was giving me issues but have replaced it and not sure how to clear these lights
  2. Brian1954
    Brian1954 Senior Member
    2,161
    839
    South Central PA, USA
    Have you tried using a OBD2 scanner to read the trouble codes?
  3. ChapmanF
    18,084
    The "how to clear these" question puts the cart before the horse.
    What you really want is to find out why they are on. Then you can fix that, which is the real way to get the lights to stay off.
    If you don't have an OBD-II scan tool that is able to read the brake system codes, you can read them like this:
    Blink (a/k/a Flash) Codes – How to. | PriusChat
  4. 2genowner
    Rhode Island
    odbII scanner showed no codes but i hooked up tech stream and got the codes
    C1343 Hydraulic issue rt rear. I did replace the leaking wheel cyld on that side and I let it gravity blead maybe need to do more
    B1831 Open in Driver Side Curtain Shield Airbag (D) Squib Circuit
    A couple Air conditioner ones but not worried about those right now
    B1271 History as I already replaced the Capacitor
  5. Brian1954
    2,161
    839
    It sounds like it is time to do a proper bleed procedure. Also, check the drum brake adjustment.
    #5 Brian1954, Nov 11, 2025
  6. Tombukt2
    12,908
    2,318
    Go back and look at that wheel cylinder and make sure the brake shoes are in the slots correctly on the wheel cylinder if not notice the one that's not correctly in is push the Piston out far enough that fluid is dripping right down the backing plate and onto the inner part of the wheel push that back in align the slot with the tabs put that back and adjust smartly
