Suggested work during head gasket fix
Discussion in 'Gen 3 Prius Technical Discussion' started by Frontporch, Nov 11, 2025.
  1. Frontporch
    Frontporch Active Member
    525
    117
    Nj
    I have a 2012 Prius with 200,000 miles on it. The head gasket currently does not leak and oil burning is probably about 1 quart every oil change. I recently cleaned the intake manifold in EGR cooler. PCV is new and a catch can was installed.
    I was considering replacing the head gasket as a preventative fix sometime this winter. I will be using a FelPro replacement gasket kit. I am looking for suggestions for other work that can be done while the head is off and the motor is partially disassembled
    With the pistons exposed is there any benefit to try and soak the rings for any length of time? Any products and procedures that have worked? I really don’t want to take the motor out to replace the rings.
  2. Mendel Leisk
    41,412
    How come? People say the FelPro head gasket is better, but is it, or would a new Toyota gasket serve just as well? In other words, was the Toyota gasket “defective”, or is it’s failure (anticipated failure in your case), due to “extenuating circumstances” (EGR chock-a-block full of carbon). Too, with either the Toyota head-end or full-rebuild gasket kits, you’re getting a complete set of genuine Toyota gaskets/o-rings/seals, whereas (by reports here) the FelPro kit is less complete, and largely an assortment of “this’ll do”, generic.
    Also, FWIW, the Toyota head gasket has been revised
    How many miles between oil changes?
  3. Brian1954
    Brian1954 Senior Member
    2,191
    860
    South Central PA, USA
    I would replace the engine water pump and thermostat if they have not been replaced previously.
    JC91006 likes this.
  4. JC91006
    JC91006 Senior Member
    16,768
    8,565
    I feel it probably is not necessary to replace the head gasket prematurely. If you keep the car coolant relatively fresh (change every 50k) and replace the water pump every 150k miles, you should be good. I have a 2012 with 245k miles and a 2010 with 180k miles. Both all original engines but I've replaced the water pump and kept up the coolant changes. No symptoms of head gasket problems so far.
    It also doesn't hurt to keep the EGR circuit nice and clean, I feel this is usually a 1 time thing at 120k miles. I've checked mine at 200k miles and it didn't have much build up.
  5. ASRDogman
    ASRDogman Senior Member
    7,571
    3,905
    It doesn't hurt to do it, for peace of mind, and then you won't have to worry about it.
    Soaking doesn't really help, unless you are going to do it for several times a day for several day,
    and then it still might not work.
    Think about the path the fluid has to take, and the space it has to take.
    Since you are not burning oil, well, much oil. MAYBE using the restor and protect could maybe help keep
    it that way.
    There are several products, but they have not really been proven to work.
    Frontporch likes this.
  6. Frontporch
    525
    117
    Nj
    I have only owned the car for a year. The eGR was not cleaned so I wouldn’t assume anything beyond oil changes was done
    water pump is new. Thermostat is a good item to replace
  7. Frontporch
    525
    117
    Nj
    I was under the impression that Toyota was made for new parts and Deloris design seals better on a replacement
    Good point. The extra $ is justified by the effort involved
    I do my oil change and filter at 5000 miles. Most miles this time was highway
  8. Frontporch
    525
    117
    Nj
    Is that an additive?
  9. ASRDogman
    7,571
    3,905
    No, it's Valvoline Restore and Protect oil.
    In theory, it is supposed to remove all the carbon on the pistons and between the piston
    and rings.
    It doesn't really work to clean, at least not for me after 8 or 9 or 10 or so changes.
    But it "might" work to help keep the carbon from building up....
  10. rjparker
    10,136
    6,298
    You can pour all the additives known to man over a years period and they won't fix oil burning caused by low tension rings. It has nothing to do with piston oil return passages or clogged rings. In fact people who have replaced the pistons and rings found neither clogged. But new pistons and rings fixed the oil burning and subsequent carbon buildup.
    Toyota revised the head gasket for gen3s so it's your choice.
    Some shops do recommend preemptive hg replacement, primarily because it can prevent the damage a leaking hg often creates including overheating. bent connecting rods or a hole in the block. Does anybody actually do a preemptive hg? No.
  11. JC91006
    16,768
    8,565
    Another reason I don't like to do big repairs preemptively is because you may not do it correctly or end up breaking something else. So you have a perfectly good car, that you just broke because you wanted to do a preemptive repair on something that's not broken.
  12. ASRDogman
    7,571
    3,905
    I take it you don't change your engine oil, right? It's not broken so why change it?
    Wait until the engine seizes, then change it, along with the engine....
    Since you are not having an issue, it's not really an problem.
    But it you pay attention to it, and keep an eye on the coolant where it sits when the car sits overnight,
    and when the engine is hot from driving a while, and you stop for fuel. Check the oil, and coolant levels
    while the pump is pumping...
    And if the engine knocks on restart after fueling, or sitting a short while, while you're in the store, it "might"
    be the very early stage of a failure....
    And start buying the parts you need to do the job. Then you're be ready for it....
  13. Frontporch
    525
    117
    Nj
    Thanks for all the replies. I get that the head gasket does show signs of failing before you are overheated and in much worse shape.
    I don’t need the car every day so my plan was to tackle it while the weather gets s not too terrible.
    I was also considering some battery maintenance. Cleaning the fan and shuffling the cells. Maybe new nuts and new bus bar…or whatever that is called
  14. JC91006
    16,768
    8,565
    If you're going to spend the time doing all the work you are planning for the battery, then you should just go and buy a slightly used battery and change it out. That is going to be a guaranteed failure in the near future. More so than the head gasket.
    Your battery is from 2012, changing that ahead of time and selling your working old battery would be ideal.
  15. Frontporch
    525
    117
    Nj
    I have owned several 2nd gen Prius and never knew how to get a battery other than new from Toyota.
  16. JC91006
    16,768
    8,565
    A wrecking yard would have slightly used ones. With so many models of hybrids on the road (camry, rav4, sienna, etc), there are plenty of used ones from wrecks for half the price of new. All you would need is the ability to take the modules out and put them in your car.
  17. Mendel Leisk
    41,412
    Doing this in a driveway, carport, garage, heated garage?
  18. Frontporch
    525
    117
    Nj
    Garage. Not heated. But could get a space heater. I am lucky that I don’t need the car every day and have an odyssey should I need to get somewhere
  19. Frontporch
    525
    117
    Nj
    I did a quick search online and it looks like the newest compatible donor for battery cells from any toyota model would be a 2016, so not that new. From what I remember age matters as much, if not more than mileage, so there wouldn't be anything recent other than a car with a pack replaced from Toyota (that's a needle in a haystack).
  20. JC91006
    16,768
    8,565
    All the current generation Rav4, Camrys, Sienna, and possibly others all work. The modules are all the same if they are NiMH
    There are Sienna batteries with 40 modules from 2024 for $1500. You use 28, sell the other 12.
    Rav4 will get you I believe 34 for about $1000. Use 28, sell the other 6
