Smaller Wheels On A Gen 5: Is There Any Consensus?
Discussion in 'Gen 5 Prius Main Forum' started by VelvetFoot, Nov 11, 2025.
  1. VelvetFoot
    VelvetFoot Active Member
    532
    170
    New York State
    2026 Prius
    Before I pore through all the threads, is there any summary, or consensus, on using smaller wheels on a Gen 5.
    I'm thinking in terms of economy, weight, snow, ride, looks, handling (not expecting an improvement), go-in-sno, caliper clearance, availability of wheels/tires, etc, etc.
    How about 15" wheels? Calipers looks small enough for clearance purposes.
    A 205/70R15 would be +.4%.
    #1 VelvetFoot, Nov 11, 2025
  2. Paul Gregory
    Paul Gregory Senior Member
    2,122
    555
    Alberta
    2024 Prius Prime
    XSE
    I'd trade in my 19s for a smaller tire. The rough ride is like a punch in the kidneys all the time.
    Tande and hill like this.
  3. VelvetFoot
    532
    170
    New York State
    2026 Prius
    Going through the threads...looks like 15" wouldn't fit over the calipers.
    So, I guess it would be a 16" wheel and a tire that's actually purchase-able, lol.
  4. Mendel Leisk
    41,317
    Even 16” rims are iffy. Someone here went with 16” rims for snow tires, found the hidden weights (wafer weights with adhesive, applied to inside diameter of rim) were brushing the caliper, had to be shifted slightly.
    It is a little puzzling, the wheel sizes Toyota opted for, considering the car’s weight, class.
    otatrant likes this.
  5. VelvetFoot
    532
    170
    New York State
    2026 Prius
    My MINI also had a rarer 195 tire. I went to 205 which just fit. What is it about 195?
  6. Mendel Leisk
    41,317
    3rd and 4th gen stock tire was 195/65R15. But yeah in 15” that was a very common size, sensible aspect ratio.
  7. Trollbait
    12,504
    Narrower means pushing less air out of the way. The i3 uses 175.
    I think to increase contact patch area, narrower tire means bigger wheel.
  8. Paul Gregory
    2,122
    555
    Alberta
    2024 Prius Prime
    XSE
    I know that tire width makes a difference; experimental high mileage vehicles have narrow wheels.
    But the difference is so small that it pales compared to ride comfort.
    #8 Paul Gregory, Nov 11, 2025
  9. Winston Smith
    Winston Smith Active Member
    357
    240
    OH
    2024 Prius
    LE AWD-e
    That's a reasonable explanation. My inner cynic wonders whether the driving reason for the 19 inch wheel is that it looks more like an artist's rendering.
  10. Trollbait
    12,504
    Style does become a factor. Also could be the in thing for the market Japan too.
  11. VelvetFoot
    532
    170
    New York State
    2026 Prius
    Interestingly, an OEM-looking hubcap is available on Amazon:
  12. KMO
    KMO Senior Member
    1,947
    676
    Finland
    2023 Prius Prime
    I believe that iffy experience would have been on an AWD or PHEV car, which have bigger front brakes. 16" on an FWD HEV is probably okay.
    Mendel Leisk and VelvetFoot like this.
  13. villageidiot2
    villageidiot2 Junior Member
    33
    17
    2024 Prius
    I’ve been running 16s on my ‘24 Limited FWD HEV for nearly a year and no issues at all.
    otatrant and VelvetFoot like this.
  14. VelvetFoot
    532
    170
    New York State
    2026 Prius
    Can I ask what width wheels and size of tires?
  15. villageidiot2
    33
    17
    2024 Prius
    Tire: 205/65 R16 (Vredestein HiTrac All Season)
    Wheel: Desmond Regamaster Evo II (16x7)
  16. VelvetFoot
    532
    170
    New York State
    2026 Prius
    thanks.
    villageidiot2 likes this.
  17. Paul Gregory
    2,122
    555
    Alberta
    2024 Prius Prime
    XSE
    If fuel economy were the only consideration, the car would look like a long needle with pizza cutter wheels.
