Ive tried everything to get the air bleed procedure to complete but it is not working. I replaced the master cylinder and abs accumulator a few months ago and have not been able to do the bleed procedure. I bought a 50 amp charger, im reading 14 volts when i try to start the procedure and its still not working. I got the vxdiag cable. I was trying to use it with techstream 18, Ive now signed up for the toyota two day subscription ands its still not working I also have a code for steering angle sensor. I replaced the clock spring with steering angle sensor twice with used oem ones from ebay and steering angle sesnor is still not reading, it always reads 850.5. I checked the voltage and resistance checks for the l51 connector that is said to do in the manual, its still not working. Ive attached the DTC's im getting. Im so desperate to get this to work, ill do anything, somebody please help.
50 amps??? OUCH! That is WAY too much for the 12v battery. 5 amps is enough. What device are you using for the procedure? Is it an aftermarket techstream cable? If so, that is likely your issue. It's common. Some say there is a certain cable to buy to get it to work. alteck has a tool, I'm not familiar with it, but others are. I have the D8Tools device that is very good. I'll be using it when I do the brake job in the future.
I've tried multiple cables. Nex IQ USB link 3 ($800 adapter for heavy duty diesel) , the vxdiag vcx nano, i tried using my friends scan tool, with all of them i immediately get and "air bleeding failed" message when i try to start the procedure. Ive verified that the parking brake switch is showing on, brake pedal switch showing off, etc. I do notice that some of the accelation/deceleration sesnors are displaying a non zero value when the car is stopped and i'm trying to do the procedure? could this be causing it to fail? Also i should note that a few months back i had blown the 125a fusible link and bypassed it.. Not sure if that would have any impact because i am reading 14 volts in tech stream not in ready mode when i have the charger connnected. Abs Data by George Jung posted Nov 2, 2025 at 11:52 AM
I seem to remember someone saying the car had to be on, but not ready? I'm not really sure. It was a while ago. Perhaps search prius chat for that procedure and you'll find the issue. A lot of people seem to have a similar issue. Usually it's because of a pirated copy of techstream, and/or cable. Maybe try it with the parking brake off? Or the opposite of where it is while your bleeding? I think you can just do a regular bleed procedure, instead of going through the whole thing again. I don't know about the other sensors. But since you have the scan tool, you want to check why they are showing zero, and if that is normal or not. Obviously, you should check all the wiring to make sure nothing is damaged. You can get the Xtool D8 (and now D9) for less than $800.
I've tried everything that's been suggested in previous threads, amd the manual, short of replacing the ABS actuator again, as i just put a brand new one in there a few months ago. I spent the $80 for the two day license and used the official Toyota TIS software or whatever its called now. Ive spent hundreds of dollars on multiple cables and dongles that were said to work by people on here. VXDiag, mongoose, high dollar scanners, etc. I recently bought the TopScan Bluetooth dongle that a person on youtube posted a video using to complete the bleed procedure. This time it actually allowed me to go through the steps, but i didnt hear the pump running at all. Well I would herar it turn on for a split second and stop as I pressed next on each step. I was just getting one burst of brake fluid. The pump also performs the same way when i activate one of the ABS relays on the utility menu on Techstream. I Hear it for a split second then it turns off. Is there anyway i can do any troubleshooting to verify that a new ABS accumulator will actually fix the problem, because i doubt it. Could it possibly be a bad ECU or something, even though the CANBUS check isn't showing any issues? Please somebody help, ill pay for a virtual consultation if they can walk me through troubleshooting my ecu and whatnot with a multimeter.
If this is a gen 3, the ECU is included in the actuator assembly. Didn't see this post earlier. No ouch. 5 amps is on the battery label for a charging current. The car is IG ON while you're doing the bleed procedure, and the car's electrical equipment is drawing power. At a Toyota dealer, doing any sort of long procedure where the car has to be IG ON, they'll have something like this hooked up to the battery: It won't be set for 'charge' mode, but for 'power supply' mode. It's supporting the power being used by the car, so the 12-volt battery does not lose charge.
