Help with Dr prius message
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Vickstew, Nov 13, 2025.
  1. Vickstew
    Vickstew Junior Member
    25
    kirkliston
    Hi folks.
    My prius threw up some lovely dashboard lights today and when I checked the Dr. Prius app there were no engine codes or hybrid battery codes. There was just a message at the bottom of the screen saying 'resethead error broken pipe'..(I've added pics of that message and of the dashboard lights).
    I've looked online but have no idea what this means. I don't have my good OBD2 diagnostic tool at home atm either. I just wondered if anyone had any idea what this could be.
    Thanks
    51,897
    no idea, any symptoms?
    Vickstew likes this.
  3. Brian1954
    Brian1954 Senior Member
    2,187
    859
    South Central PA, USA
    The Dr Prius app is very limited with what trouble codes it is able to read. Try downloading and installing the "Car Scanner ELM OBD2" app.
    teasy, priumium and Vickstew like this.
  4. ASRDogman
    ASRDogman Senior Member
    7,571
    3,905
    Likely a wheel sensor.... ABS. The Dr. Prius app doesn't read ABS
  5. Vickstew
    25
    kirkliston
    Brakes are not as sharp and strangely the car still pulls from the hybrid battery when the car is fully stopped but not in park.
  6. Vickstew
    25
    kirkliston
    Thanks for the reply Dogman. I'll have a check of that once the weather dries a bit.
  7. Vickstew
    25
    kirkliston
    Thanks Brian. I have a good OBD2 scanner but my brother has it the noo. Will give that a go in the meantime
  8. ChapmanF
    18,149
    The car is programmed to act like a conventional auto-transmission car, which also has a pull when stopped but not in park, so that's normal for a Prius.
    If you don't have a scan tool nearby that can get you the brake system codes, you can get them this way:
    Blink (a/k/a Flash) Codes – How to. | PriusChat
  9. Vickstew
    25
    kirkliston
    Well thank you Brian and Dogman.
    I got that app and did a scan and it came up as a left rear wheel speed sensor error. Took the tyre off this morning and cleaned both sides of the connector with electrical cleaner.
    Seems to have solved the issue so far. Will take it on a longer drive this afternoon just to make sure.
    Thanks again xx
    ASRDogman and Brian1954 like this.
  10. Vickstew
    25
    kirkliston
    I had just never noticed it do that before...lol
  11. Vickstew
    25
    kirkliston
    Alas the issue has come back again.
    Code C0215 - Left rear speed sensor circuit.
    Looks like I will have to look into it further. Joy.
  12. ASRDogman
    7,571
    3,905
    How old are your hubs? If they are oem, it just may be time to replace them.
    Check all the connections and for damaged wiring.
    Normal use will eventually cause metal flakes to get stuck on the magnet.
    And the hubs aren't easily taken apart to clean the sensor like on the fronts.
  13. Vickstew
    25
    kirkliston
    Thanks for the reply dogman.
    Tbh I think the hubs are OEM and it's a 2009. It was an import from japan. I checked all the wiring and nothing seems damaged. I rechecked the hubs and there does seem to be a wee bit of play when you move the wheel so I think I'll probably need to replace the hub. The pads n brake disc sheilds need replaced soon anyway so I might as well do it all at once. Was hoping for an easy fix but it normally never is!
  14. ASRDogman
    7,571
    3,905
    The hubs themselves could be fine, but the sensor is bad.
    I believe the 2009 hubs are the same type as the Gen 3, one piece.
  15. Vickstew
    25
    kirkliston
    Yeah they are integrated.
    I replaced it today. Thank god I bought a brake disc shield at the same time cos the two were completely fused together! I put anti seize paste on this time to try to stop that happening again.
    Lights are back off but will take for a long drive later to make sure. Fingers crossed.
    And ty again x
    ASRDogman, Brian1954 and bisco like this.
