Rodent proofing ventilation intake
Discussion in 'Gen 5 Prius Main Forum' started by Templeton, Nov 12, 2025 at 11:05 PM.
  1. Templeton
    Templeton Member
    261
    74
    usa
    2024 Prius Prime
    SE
    Are there any toyota or aftermarket products out there that allows a gen5 owner to install a metal screen (or similar) just above the cabin filter?
    Apparently, there is such a product for the rav4, so l was wondering if such a product exists for the gen5 prius.
  2. Blackat
    Blackat Active Member
    450
    309
    Colorado
    2023 Prius
    Limited AWD-e
  3. Templeton
    Templeton Member
    261
    74
    usa
    2024 Prius Prime
    SE
    Sure, but where is the intake?, how do you access it on the gen5?, anyone do this?, what kind of screen did you use?, what kind of attachment did you use for the screen, any links or videos or info?, etc.
  4. PriusCamper
    PriusCamper Senior Member
    12,647
    5,108
    Pacific Northwest, USA
    If you live near me I'd be happy to do it for you and post pictures on this thread too.
  5. Templeton
    Templeton Member
    261
    74
    usa
    2024 Prius Prime
    SE
    Are you in the Midwest?
    It surely is not super hard, l just was wondering if anyone has done this, and maybe had some pointers?
  6. PriusCamper
    12,647
    5,108
    Gen5 is so new, you'd do a great service to fellow Gen5 owners to figure it out and post photos.
  7. Templeton
    Templeton Member
    261
    74
    usa
    2024 Prius Prime
    SE
    Will definitely do that if I am the first on the planet to do this mod.
    But, if not, I was just wondering if anyone has done this previously, and maybe had some pointers or suggestions?
  8. Trollbait
    12,491
    All the cars I've owned had to intake under the plastic shroud at the base of the windshield; passenger side. Only ever had to remove the shroud on the Taurus and Sable. The cabin filter was actually installed there for those models.
    Instructions of removing it on the gen5 are likely in the repair manual.
    Complete Gen 5 (2023+) Repair Manual Available | PriusChat
  9. VelvetFoot
    VelvetFoot Member
    472
    142
    New York State
    2026 Prius
    I found a mouse nest in the engine airbag in a VW I had.
  10. VelvetFoot
    VelvetFoot Member
    472
    142
    New York State
    2026 Prius
