Adding Push Button Start to Base Model Aqua
Discussion in 'Prius c Audio and Electronics' started by ptrustfull, May 27, 2022.
  1. ptrustfull
    ptrustfull Junior Member
    24
    Suriname
    2012 Aqua
    i have recently purchased a 2012 Aqua, same as Prius C, with the traditional key. I want to add push button start to it. The only problem is to find the wire that is active when the car is "ready". Does any one ever delt with this before and is willing to share that information.
  2. ptrustfull
    24
    Suriname
    2012 Aqua
    I sucseeded in installing the pushbuttom start by using the wiring diagram of a Vitz/Yaris. Even without the wiring diagram it's easy to install
  3. Leadfoot J. McCoalroller
    8,133
    7,631
    Pennsylvania
    2018 Prius c
    Do you still need the key to unlock the steering etc?
