Rodent proofing ventilation intake
Discussion in 'Gen 5 Prius Main Forum' started by Templeton, Nov 12, 2025.
  1. Templeton
    Templeton Active Member
    321
    114
    usa
    2024 Prius Prime
    SE
    Are there any toyota or aftermarket products out there that allows a gen5 owner to install a metal screen (or similar) just above the cabin filter?
    Apparently, there is such a product for the rav4, so l was wondering if such a product exists for the gen5 prius.
  2. Blackat
    Blackat Active Member
    473
    334
    Colorado
    2023 Prius
    Limited AWD-e
  3. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    Sure, but where is the intake?, how do you access it on the gen5?, anyone do this?, what kind of screen did you use?, what kind of attachment did you use for the screen, any links or videos or info?, etc.
  4. PriusCamper
    PriusCamper Senior Member
    12,956
    5,268
    Pacific Northwest, USA
    If you live near me I'd be happy to do it for you and post pictures on this thread too.
  5. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    Are you in the Midwest?
    It surely is not super hard, l just was wondering if anyone has done this, and maybe had some pointers?
  6. PriusCamper
    12,956
    5,268
    Gen5 is so new, you'd do a great service to fellow Gen5 owners to figure it out and post photos.
    PrimeDan likes this.
  7. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    Will definitely do that if I am the first on the planet to do this mod.
    But, if not, I was just wondering if anyone has done this previously, and maybe had some pointers or suggestions?
  8. Trollbait
    12,646
    All the cars I've owned had to intake under the plastic shroud at the base of the windshield; passenger side. Only ever had to remove the shroud on the Taurus and Sable. The cabin filter was actually installed there for those models.
    Instructions of removing it on the gen5 are likely in the repair manual.
    Complete Gen 5 (2023+) Repair Manual Available | PriusChat
  9. VelvetFoot
    VelvetFoot Active Member
    1,085
    411
    New York State
    2026 Prius
    I found a mouse nest in the engine airbag in a VW I had.
  10. VelvetFoot
    1,085
    411
    New York State
    2026 Prius
  11. futurist
    futurist Member
    55
    97
    United States
    2024 Prius
    Interesting -- I don't park near tall grass fields or other mouse habs but who knows what they do, arse-crack of dawn...
    Has anyone seen any evidence of mice eating wiring harnesses on our Priuses?
    With biodegradable insulation on most harnesses since the early '90s, the less-fortunate marques (like Honda, Mazda, & M-B) have had lots of PITA repairs on components which can often require the entire effing vehicle be taken apart to fully repair. Or at least it'll look and feel that way, to the hapless dealer tech whose got your RO on his bench. Lived in WA a bit so if you're gonna have hantavirus-y furballs making your vehicle their home, toilet, and graveyard, gonna be there :oops:
  12. mingc
    mingc Member
    69
    46
    Portland, OR
    2023 Prius
    XLE AWD-e
    Not my current 5th gen, but one morning my former 3rd gen would not start and neither a jump or fob next to power button trick did anything. My mechanic found a chewed through harness. I knew it was squirrels because they lived in my trees and I'd find droppings in the engine compartment. After a few weeks of checking under the hood randomly everyday, they eventually stopped visiting the car.
    futurist likes this.
  13. RX808
    RX808 Junior Member
    31
    2025 Prius Plug-in
    XSE Premium
    Good Question - I took apart the wiper area on mine to see about adding screening - I did it on my 2017 Prius (and other cars) without a problem. This one? It gets awfully narrow and tight in the Gen5 HVAC air intake area, so I gave up and buttoned it back up. I'll wait and see if I do get mice through there - usually you can tell right away by checking the cabin air filter. I did add screens @ HVAC (exhaust) body vents in the rear, R+L, as I've had mice come in there on my other Toyotas.
    Also, do you have a link for that product? Might be nice to see how an engineer solved the problem ;)
  14. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    Sure. Apparently, this is the one that some rav4 owners are putting on their air vent inlet ducts:
    https://www.aliexpress.us/item/3256803069294711.html
  15. Blackat
    473
    334
    Colorado
    2023 Prius
    Limited AWD-e
    I think adding mothballs or something as a deterent would be easier if you have this problem
  16. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    Where would you put them, such that they would be secure while driving ?
  17. Mendel Leisk
    41,788
    C'mon...
    Wipers, linkage and motor will very likely need to come off, bottom of window trim, and underlying metal cowl. Opening is typically in the firewall, driectly forward from the glove box.
    PriusCamper likes this.
  18. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    I am confused. Do people not use internet forums to learn new things with the help of others?
    RX808, PrimeDan and Mendel Leisk like this.
  19. Blackat
    473
    334
    Colorado
    2023 Prius
    Limited AWD-e
    I don't know, it was a suggestion. I don't have this problem to take it further
  20. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    No worries, thanks for the suggestion.
    To anyone that might know, are there any aftermarket intake vent covers out there for the gen5 ?
    Blackat likes this.
