Tire Rotation
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by peteseltz, Aug 11, 2009.
  1. peteseltz
    peteseltz New Member
    Philadelphia
    Toyota says every 5,000 or every oil change. This a good standard to keep or is it not worth the extra $20?
  2. jay_man2
    jay_man2 jay_man_also
    1,246
    144
    Manassas, VA
    It's what I do. Never had a tire issue on a Toyota.
  3. bokone
    bokone Junior Member
    25
    Columbus, OH
    Am I correct. You need to re-initialize the TPMS sensors for a front to rear switch?
  4. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Since the fronts take a different pressure than the rears (at least on the 17" wheels) you should reset it after rotating and filling with the correct pressures.
  5. richard schumacher
    7,666
    1,047
    United States
    Not necessary. The front tires wear faster, but that's fine because it's safer to have the less-worn tires in the rear to reduce the chances of fishtailing. Let the front two wear out, then move the rear two to the front and put two new ones on the rear. Note that this does not reduce the total life of the tires.
    If uneven or unusual wear occurs on tires it indicates that they are poorly balanced or that there is a suspension or alignment problem. Any of those conditions should be repaired; merely rotating the tires only masks the problem.
    Botany Bill likes this.
  6. bokone
    25
    Columbus, OH
    I don't agree on NOT rotating the tires. The fronts steer and power, the rears are just along for the ride and with the power of the Prius, I wouldn't worry about the rear end passing the front. Severely worn fronts on the other hand will be handful when the weather turn bad. Just my $.02
  7. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    I will change to a different type and brand of tire when the originals are worn out so I like to have them all 4 wear out at about the same time. I also want the same brand and type of tire on all 4 corners. But rotating tires every 5K miles is not necessary and as Richard S. said above it can mask suspension/alignment problems.
    I plan to rotate my tires at about 10K miles and then again at 30K, when I reach 40K they will all have spent the same amount of miles on the front and back. At that time if there is sufficient tread left I may move them round to finish using them up. I replace them when I can't see George Washington's head on a quarter or when some kind of defect shows up.
  8. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Cross-rotating the tires is also important for even wear. Although it isn't directly applicable to the Prius, a tire rotation is an opportunity for a brake inspection. On most cars, this is important.
  9. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    My .02
    The 5K tire rotation is akin to the Prius 5K oil change. But now IMO - overkill - and an wonderful way to pad the cash register at the Service department.
    5K rotation worthy in the 70s-80s with poor suspension and tires. As with shampoo makers - "Rinse and Repeat again" - doubles profits.
    Unless it's included at a reasonable cost during an oil change, I'll plan a DIY about every 10K miles. Nice opportunity to look around each wheel well and each corner's wheel/brake components.
  10. Glider
    Glider New Member
    135
    30
    Memphis
    Rotating your tires often is very good - the only question is: is it good for your car or your dealership? Some carmakers (like BMW) recommend against it.
    Since rotating every 5,000 miles means 9 rotations in the average tire lifetime of 50,000 miles, that comes out to $225 assuming 25 bucks a shot (maybe $275 counting lost interest on your money). The small additional tire lifetime is not going to recoup that amount. Then there is the extra waiting, the resetting of your pressure sensors (since front and rear pressures are different), etc.
    Maybe rotating 2-3 times in the lifetime of the tires is reasonable, but if you keep them at high pressures, you won't have anything to worry about. This is just MHO.
  11. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    Depending on what tires you have I'm guessing you may never get to the second rotation. I'm hopeful, but doubtful, that my 17" Bridgestones will ever see 30K miles. My TCH tires wore out at 24K (both sets) before I switched to Michellin's.
  12. MikeDS
    MikeDS Member
    298
    Los Angeles
    Why not just go to Discount Tire Co or American Tire Co? They rotate for free...
  13. tumbleweed
    4,067
    692
    Eastern Oregon
    I sure wouldn't say you are wrong, but I hope you are. I too know wide low profile tires can wear out in a hurry. The Dunlops on my BMW didn't even last 20K on the rear, fronts would have lasted about 30K. They were different sizes front and rear and directional so no rotation was possible.
    My Prius has Toyo Proxis A20 and I have no experience with them. Tread wear is only 300 so I don't expect to much. When they wear out I'll most likely go to Michelin Pilot Sport A/S, I had a set of them and they were very good.
  14. ceric
    ceric New Member
    1,114
    Fremont, CA
    I don't understand why people rotate tires on a pre-set schedule.
    One can see the condition of tires (tyres) visually.
    Do it when necessary. Save money rotating them unless you DIY and you see that as an exercise.
  15. Botany Bill
    Botany Bill Junior Member
    Keyport, NJ
    I had always heard to have the better pair on the fronts on a front-wheel drive car. Then I read a Tire Rack article saying why they should always be on the back - for better breaking and that's far more important. At that time, I was buying just 2 for my old Honda Fit. My mechanic also said to put them on the front, so I ignored Tire Rack. BAD CHOICE. Within a month, I was on an off ramp going about 40 mph in light rain on a curve and my rear fishtailed like I was on snow. (I was about 50 yo, with plenty of driving experience in all weather in many cars in the northeastern US.) Totaled the car. I can't believe I had just read that article, ignored it, and learned my lesson so quickly. Never again. If I ever only replace 2, they will always go on the rear.
    VelvetFoot likes this.
  16. indel
    indel Member
    274
    88
    Northwest Indiana
    Winter tires are directional. They cannot be cross rotated. DF <--> DR and PF <---> PR only!
