HV battery replacement
Discussion in 'Generation 1 Prius Discussion' started by joegr, Nov 7, 2025.
Tags:
  1. joegr
    joegr New Member
    GREECE
    2003 Prius
    I
    My Prius Gen 1 2003 had a battery replacement with new one 1,5 years ago with 210k km, a month ago the car suddenly lost power on the road and I forced to stop, current milage is 215k km.
    The garage had to check and clean injectors and also check fuel pump pressure.
    The HV battery was low and was sent for reconditioning.
    When reconditioned HV battery placed back on the car it could not start, the technician found that battery voltage on many cells was dropping to a range 1v-10v when attempting to start.
    The opinion was that the HV battery seems to be destroyed and has to be replaced with new or replace many cells.
    Finaly HV battery was sent for reconditioning for second time and hope for the best.
    The question is whether is justified for new HV battery to collapse in 1,5 year.
  2. vaughnstark777
    190
    33
    Roy, WA
    2001 Prius
    I
    There are some very “fishy” things about your situation. A bad module can get down to 1 volt but I don’t believe a good one can charge much past 8 volts. If your battery pack was indeed new then, no it shouldn’t go bad in a year and a half. If it was a “reconditioned” pack then, depending on the attention to detail, yes it may not last long. But if you got it from a reputable source it should have a warranty. Lastly it seems very fishy that a mechanic would not plug in a scan tools before attempting to fix your problem. The scan tool would notice the battery problem even if you needed injectors. If there was no battery problem before you left the car with the mechanic I would start asking a lot of questions!
  3. joegr
    joegr New Member
    GREECE
    2003 Prius
    I
    t
    Tha
    Thanks for your answer ,
    I saw the installation of new battery 1,5 years ago coming from a wooden box in TOYOTA dealer, the warranty the give is one year, the mechanic in the authorised dealer told me 'see how you can deal with it' meaning pay for reconditioning.
    I try to find a HV charger like maxx volts, prolong, but need to have a mechanic willing to do it. The problem they put is that I move the car once a week doing 100km.
    I visited a HV specialist suggesting to start the engine every day for a while will keep the HV battery alive? He also told me that if I can keep charging the 12v battery in a closed parking from main will maintain the HV battery ??
    I wait to see the cost for reconditioning ..
    Do you know any charger for Gen1 ? I read that Gen0 had a built in charger , using a 12v battery to recharge the HV battery
  4. dolj
    dolj Senior Member
    8,495
    4,313
    Wellington, New Zealand
    Unless your circumstances change so you can drive the car more regularly, you should consider selling it and just replace it with a cheap, economical petrol car. The hybrid vehicle battery does not fare well with the usage you describe.
    Having said that, I find it hard to believe the battery failed after 1,5 years. It makes me think you were scammed, or didn't understand that the battery was a reconditioned one, not a factory-new one.
  5. joegr
    joegr New Member
    GREECE
    2003 Prius
    I
    Thanks for your answer, yes I consider replacing if things can get better. I paid 2500 euro hoping the battery was new!
    Any idea of a good working charger?
  6. dolj
    dolj Senior Member
    8,495
    4,313
    You can buy a charger (Hybrid Automotive Prolong, Maxx Volts, or Venice Hybrid Tech, for example, if you can import from the USA) or build your own for less than $100.
  7. joegr
    joegr New Member
    GREECE
    2003 Prius
    I
    Today they told me the cost to rebuild , 900 euros with 6 months warranty, total cost with labour 1200 euros
    I try to find a technician to wire the charger to HV battery. I will need it later, HV is sensitive and cells fail from time to time
    A mechanic told me that Gen 1 should not get Litium cells ??
    Enno Car offers new battery cells around dor 1600 $ for 38 cells
