Prius Tire Valve Cap
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Gokhan, Oct 29, 2025.
  1. Gokhan
    Gokhan Senior Member
    6,140
    2,430
    Paramount CA
    Yeah, I should probably order an engine and a cabin air filter, too.
    Those little parts are packed in bags of ten but sold individually. Chances are that you will get two unopened bags. If you order less than ten, they usually give them to you in the original bag with the number ten struck through and the actual number handwritten and store the rest in a bin in their stockroom. Did you order the 90942-05039 or the 90942-A5002? They should be the same Pacific Industrial Co., Ltd. part made in Japan in any case with only the packing country being different.
  2. Gokhan
    6,140
    2,430
    Paramount CA
    Apparently, the Toyota part number for the made-in-Japan Pacific Industrial Co., Ltd. CL-type non-TPMS tire valve cap is 90942-05035.
    The following image from the Toyota parts catalog shows the Pacific CL-type non-TPMS tire valve cap (large cap in the bottom-left drawing) and PVC25-type TPMS tire valve cap (small cap in the top-left insert). Apparently, the brand for the TPMS monitor is Pacific itself per the FCC labels in the bottom insert.
    #42 Gokhan, Nov 18, 2025 at 3:51 PM
  3. Gokhan
    6,140
    2,430
    Paramount CA
    And the part number for the OEM light-gray/silver TPMS tire valve caps on older Toyotas is 90942-A5004. They are not made by Pacific Industrial Co., Ltd. of Japan, as all genuine Pacific tire valve caps are black.
    #43 Gokhan, Nov 18, 2025 at 4:00 PM
  4. mingc
    mingc Junior Member
    29
    Portland, OR
    2023 Prius
    XLE AWD-e
    Gokhan likes this.
  5. Gokhan
    6,140
    2,430
    Paramount CA
  6. RRxing
    RRxing Senior Member
    2,544
    1,818
    NEPA
    A "friend" told me to just go to a dealership after hours and roam around the lot. Lots of valve caps available. :rolleyes:
    Gokhan likes this.
  7. VelvetFoot
    VelvetFoot Active Member
    500
    155
    New York State
    2026 Prius
    Gokhan likes this.
