Prius Tire Valve Cap
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Gokhan, Oct 29, 2025.
  1. Gokhan
    Gokhan Senior Member
    6,144
    2,431
    Paramount CA
    Yeah, I should probably order an engine and a cabin air filter, too.
    Those little parts are packed in bags of ten but sold individually. Chances are that you will get two unopened bags. If you order less than ten, they usually give them to you in the original bag with the number ten struck through and the actual number handwritten and store the rest in a bin in their stockroom. Did you order the 90942-05039 or the 90942-A5002? They should be the same Pacific Industrial Co., Ltd. part made in Japan in any case with only the packing country being different.
  2. Gokhan
    6,144
    2,431
    Paramount CA
    Apparently, the Toyota part number for the made-in-Japan Pacific Industrial Co., Ltd. CL-type non-TPMS tire valve cap is 90942-05035.
    The following image from the Toyota parts catalog shows the Pacific CL-type non-TPMS tire valve cap (large cap in the bottom-left drawing) and PVC25-type TPMS tire valve cap (small cap in the top-left insert). Apparently, the brand for the TPMS monitor is Pacific itself per the FCC labels in the bottom insert.
    #42 Gokhan, Nov 18, 2025 at 3:51 PM
  3. Gokhan
    6,144
    2,431
    Paramount CA
    And the part number for the OEM light-gray/silver TPMS tire valve caps on older Toyotas is 90942-A5004. They are not made by Pacific Industrial Co., Ltd. of Japan, as all genuine Pacific tire valve caps are black.
    #43 Gokhan, Nov 18, 2025 at 4:00 PM
  4. mingc
    mingc Junior Member
    31
    Portland, OR
    2023 Prius
    XLE AWD-e
    Gokhan likes this.
  5. Gokhan
    6,144
    2,431
    Paramount CA
  6. RRxing
    RRxing Senior Member
    2,544
    1,819
    NEPA
    A "friend" told me to just go to a dealership after hours and roam around the lot. Lots of valve caps available. :rolleyes:
    Mendel Leisk and Gokhan like this.
  7. VelvetFoot
    VelvetFoot Active Member
    503
    158
    New York State
    2026 Prius
    mingc and Gokhan like this.
  8. Gokhan
    6,144
    2,431
    Paramount CA
    When I bought my Barcelona-red-metallic 2009 Corolla XLE from Longo Toyota in February 2008, two of the light-gray/silver OEM tire valve caps were missing. I thought that was negligence by the dealer when adding air to the tires, but now I know why. LOL
    I asked the sales guy if I could take tire valve caps from other new cars to replace my missing ones, and he said go ahead. :)
  9. Gokhan
    6,144
    2,431
    Paramount CA
  10. mingc
    mingc Junior Member
    31
    Portland, OR
    2023 Prius
    XLE AWD-e
    Oy! :X3:
    Gokhan and VelvetFoot like this.
  11. frodoz737
    frodoz737 Top Wrench
    4,681
    2,492
    33
    It's official now...50 pages about Prius tire valve stem caps.
  12. Gokhan
    6,144
    2,431
    Paramount CA
    It is the only Prius accessory everyone can afford in Trump economy. :)
  13. VelvetFoot
    503
    158
    New York State
    2026 Prius
    You politicizing this stupid thread now?
  14. Gokhan
    6,144
    2,431
    Paramount CA
    If you don’t like it, strike through “in Trump economy.” :)
  15. VelvetFoot
    503
    158
    New York State
    2026 Prius
    Delete it yourself.
    I didn't think politics was appropriate in this forum.
