Engine death rattle when starting
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by joebg, Nov 4, 2025.
  1. joebg
    joebg Junior Member
    Sanbornton, NH
    Not to be too dramatic -- that title wording just came to me, but ... on a number of occasions recently when I start my 2013 Prius (150K miles), after the initial battery start, when the engine first turns over, it rattles and vibrates for a moment, and sounds awful down there (like a death rattle), and then it reverts back to normal and drives fine. This has always happened first thing in the morning, maybe 3-4 times in the past month, maybe when it's been colder, though it's not gotten below the 30s-40's here in NH. It's concerning me, not sure how a dealer would troubleshoot this kind of intermittent problem.
    Does this engine noise/fart issue ring a bell with anyone?
    Thanks a bunch!
  2. DirkAshburn
    DirkAshburn Member
    143
    58
    Virginia
    I've seen exact same thing twice in the last couple months, both times I noticed that the shown battery level was at 1-2 bars at start. I already know I have a weak hybrid battery, so I'm thinking its related. Lately the charge had been 4+ bars always, but I'll have to try depleting the battery and let it sit abit to see if I can recreate it.
  3. bisco
    51,832
    might be hard to diagnose at this stage of the game, have you cleaned the egr circuit?
    keep an eye on oil and coolant. if it gets worse, consider a head gasket test.
  4. Mendel Leisk
    41,295
    You don't come here much? ;)
    First thing in the morning, after a good drive the day before:
    1. Remove wipers, wiper motor/linkage and cowl. (see video #13 here)
    2. Remove ignition coils and spark plugs (When reinstalling, spark plug torque spec on reinstall is 13 ft/lb with clean/dry threads, you'll need a 14 mm or 9/16" spark plug socket)
    3. If possible, remove engine coolant reservoir cap, and install gizmo to pressurize cooling system (to accelerate possible coolant leakage)
    4. Run borescope down each spark plug hole, looking for evidence of coolant seeping past head gasket into cylinder(s). It's best to have a borescope capable of looking "over it's shoulder". You're looking for exceptionally clean looking piston tops (evidence of coolant steaming off crud), and tears of coolant forming and running down from the head gasket seam.
    Has the EGR system ever been cleaned?
    Info on head gasket and EGR in my signature. (on a phone turn it landscape to see signatures)
  5. rjparker
    10,066
    6,234
    Very common early head gasket leak. Diagnose quickly and repair to avoid an engine replacement.
    Car Care Nut HG Borescope at 660s
    Block egr flow test to rule out sticking open egr. Even if egr if sticking it won't cause severe rattling that quickly clears for the rest of the day.
    At about 10:15 in the video he starts talking about the egr valve letting "air" into the intake manifold. He means exhaust gasses.
  6. joebg
    joebg Junior Member
    Sanbornton, NH
    Thanks for your reply. Clearly I have a head gasket problem, just got a P0301 error code also. But I don't work on my car. I'm going in to the dealer today to get a diagnosis. Do you have any advise for me dealing with the dealer? What steps they should take before telling me I need a head gasket replacement? Thanks.
  7. joebg
    joebg Junior Member
    Sanbornton, NH
    Thanks for your reply. Yeah, I've only come here when I've had an issue or concern with my Prius, and fortunately they have been few and far between. But clearly I've got a head gasket problem now. Just got a P0301 error code also. I don't work on my car myself. Going to the dealer for a diagnosis. Any advise you can give me to tell them to do is appreciated, or what I should be careful of in dealing with them. Thanks.
  8. Mendel Leisk
    41,295
    p0301 indicates misfire on cylinder one. It’s the cylinder where the coolant leaks usually start. Dealership will likely be very expensive, $4~5 USD region, for head gasket replacement, They make advocate to swap in a salvage engine. They don’t stoop to clean EGR, will tell you it’s ok if no code, offer to just replace components, and those parts are about a grand.
    not sure who else is doing head gasket in Seattle. There’s Gasket Masters in San Francisco, theyre cheap, and fast, but quality and after sale service can be dicey.
    to be fair: salvage engine IS worth considering, it’s somewhat overkill, and a gamble, but sometimes expedient.
  9. rjparker
    10,066
    6,234
    They may do a borescope inspection unless it's bad enough to fail a combustion gas in coolant test.
    Most dealers will offer a new short block with rebuilt head solution for $8-$10k. Generally they won't do a "simple" head gasket job because it's difficult to warranty due to comebacks.
    Other "normal" shops might do the hg alone but are still likely to charge $2.5k or more depending on how much extra work you want. Egr refreshing can be $600-$1000 alone and many go for new water pumps as well.
    Given a 2013 is rarely worth the cost of a dealer's solution and a hg alone is risky due to existing low tension rings, many will chose a pro rebuild of the block with new pistons and rings, along with a rebuilt head for half the dealer's short block solution. Others go for a JDM used in Japan engine (not US salvage) and often get a guarantee and good results for less than a pro rebuild.
    Ideally you find a small hybrid only repair shop with engine repair experience and skip the dealer repairs even if you use a dealer for diagnosis.
    A small shop near me does a gen3 engine every week and has for years.
  10. joebg
    joebg Junior Member
    Sanbornton, NH
    Dealer's analysis was:
    FFD suggest EGR was active while driving and engine temp low -- T-SB applies
    Replace intake manifold and gasket
    Replace EGR pipe and gasket
    That's it, tech guy didn't think the head gasket was involved at all. Does that make sense?
  11. rjparker
    10,066
    6,234
    If it's the egr causing stumbles the egr block flow test in post 5 above will confirm it. In that situation the egr valve is sticking open at idle and low rpms when it is designed to be closed. Blocking the flow is diy easy and is a no parts required test.
    However a sticking open egr will provide a code. It is repaired with a revised egr valve and an ecm software update.
    There is a revised intake manifold that would not hurt anything except your wallet. New means clean; revised means improved egr passsges.
    I would verify what they intend to do relative to the egr. Your note above said nothing about replacing the egr valve.
  12. Mendel Leisk
    41,295
    My hunch is it's rearranging deck chairs on the Titanic. EGR does need cleaning, and since they don't stoop to that, out comes the parts cannon. Hopefully (and likely) including the EGR valve.
    But I'd still suspect head gasket is failing, strongly, with where you are, and the P0301 code. What the heck, free EGR cleaning, but brace for head gasket.
  13. joebg
    joebg Junior Member
    Sanbornton, NH
    So what do I ask them to do to confirm or rule out that I've got a head gasket problem? Will a compression test do that? Or something else?
  14. rjparker
    10,066
    6,234
    Borescope test post 5
  15. joebg
    joebg Junior Member
    Sanbornton, NH
    Thank you all for your advise.
    The dealer did the borescope test and found "a lot of coolant sitting on top of cylinder 1 piston" confirming the head gasket is failing. Since I don't work on my car myself, I'm not going to put any money into this repair. My question is: is there any way to hazard a guess of how long before the engine craps out? I don't need to drive it a lot, but will need to do some car hunting/shopping. Is it a gradual, progressive thing? Will there be some other signs of things getting worse. And what's a 2013 Prius with a failing head gasket worth anyway?
    Thanks again.
  16. ASRDogman
    ASRDogman Senior Member
    7,535
    3,892
    No one can say. Could be a day, could be a year. If you do a lot of city driving, I would guess sooner.
  17. rjparker
    10,066
    6,234
    You are likely to get stranded soon when the leak causes severe rattling each time the engine cycles on and off. Like at traffic lights and when letting off the gas momentarily.
    As is you would be lucky to get $1000 if the rest of the car is in average condition. Maybe a few hundred more with a recent new brake booster or hybrid battery.
    Some dealers might say they are giving you $1500 as a trade in but they are just giving you a $1000 discount off a new(er) car and assuming they can net $500 at the auction.
    If it was a nice car (paint, body, interior suspension, tires) I would get a JDM (used in Japan) engine installed for maybe $2500 and then sell it for $5k.
    Never get a salvage engine from North America.
    #17 rjparker, Nov 19, 2025 at 6:25 PM
