Replacing coolant parts as a safe measure
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Inspector Gasket, Nov 7, 2025.
  1. Doug McC
    Doug McC Senior Member
    1,079
    415
    Midwest
    2022 Prius
    I believe that we often forget that dealerships are paying hourly wages, sometimes health benefits and other benefits, plus paying for extremely expensive equipment, insurance coverage, legal expenses, etc, etc, etc. all while being in business to make a profit (some times enough to satisfy shareholders). Plus paying for ongoing training for their staff. So, obviously, it will cost more to have them do a service than what most small independents need to charge, or what a DIY can do it for. While a job might be simple, they are often using equipment that insures it is done correctly and completely (such as brake fluid changes on a Prius).
  2. Mendel Leisk
    41,295
    Yeah I wonder, would the do the full brake fluid change, which I believe replaces the fluid in the brake booster components? For sure they'll be using Techstream, and maybe a high-tech vacuum extractor.
    My "equipment", doing the non-Techstream method, was"
    10mm box wrench
    8mm box wrench
    length of clear tube with bleed valve grommet on one end
    largie/empty mayo jar with lid, with hole drilled in lid
    Largish syringe with clear tube extensiion and skinny pippet nozzle (for basting out reservoir)
    Plus floor jack, jack stands, wheel chocks, impact wrench with 21mm socket, the usual rigmarole for DIY raising the car
  3. Iron Man Prius
    Iron Man Prius Junior Member
    98
    25
    Fullerton
    Three Touring
    Strang logic, like going for a simple doctor's visit then asking him to do open heart surgery on you because you stubbed your toe or something. The bypass fix is less than $100 to fix with the hose and clamps, to possibly save major inconvinience and money down the road. There's zero harm and that's all she needs to do..no one is recommending rebuilding the whole dang car.:rolleyes:
  4. Doug McC
    1,079
    415
    Midwest
    2022 Prius
    The water pump is fine and she is in her 70’s. Think about it.
  5. Iron Man Prius
    98
    25
    Fullerton
    Three Touring
    Heat Exchanger...not the water pump. Also waterpumps still fail and mostly close to the 200k mark within a reasonable frame...I'd say because she's in her 70's, lives a rural area, and can't do the work very easily is the BEST time to do preventative maintenance on the vehicle before it fails and she's stuck. Common sense.
  6. Mendel Leisk
    41,295
    If the Exhaust Heat Exchanger has not failed by now, perhaps it's ok? It's purportedly a "bad batch"?
    I'd be reluctant to jump the gun, do the bypass, considering it could be for naught. Better to just read up on the issue, and the bypass, have the warranty extension from Toyota on hand, and monitor coolant level in the reservoir regularly.
    Still, food for thought: OP's got a 2016, which is definitely early release, before the caught wind of the issue.
  7. Iron Man Prius
    98
    25
    Fullerton
    Three Touring
    It's literally not going to hurt anything doing it, and yes..being a 16' even worse. It's like saying "Oh you have a 2010, you won't have to worry about oil burning"..yeah, you will eventually.
  8. Doug McC
    1,079
    415
    Midwest
    2022 Prius
    Bypassing the heat exchanger is NOT preventative maintenance. It is a temporary fix for a failed heat exchanger, not a permanent one. Plus, doing it DOES have a negative effect on the operation of the vehicle AND the bypass itself introduces multiple new points for potential failures that could result in a sudden loss of coolant which could cause extensive damage to the engine.
  9. Iron Man Prius
    98
    25
    Fullerton
    Three Touring
    Negative as in cant get hot air through your vents immediately after start up? I'm sure that's a huge problem in the deep south. :ROFLMAO:Name all these other horrible things that will happen to your vehicle if you bypass the heat exchanger properly with the right hose and solid clamps? I'll be waiting with baited breathe...:rolleyes::whistle:
  10. Mendel Leisk
    41,295
    Well, the debaters are firmly entrenched. Leave it to OP now?
    #30 Mendel Leisk, Nov 15, 2025 at 8:27 AM
    Doug McC likes this.
  11. Iron Man Prius
    98
    25
    Fullerton
    Three Touring
    Uncle Mendel, but is it really a debate when an industry professional tries to explain to a DIY backyardigan who types opinion without fact?
    Original comment still stands as a possible pitfall warning to this poor person of age who has limited resources, it's never about ego or 1 upping someone who is "wrong on the interweb" as least from my perspective but then again, ego trumps sympathy nearly everytime.
  12. Doug McC
    1,079
    415
    Midwest
    2022 Prius
    Just out of curiosity and since you don’t mention it, have you tried the Toyota dealerships in the Memphis area (including Hernando)?
  13. Doug McC
    1,079
    415
    Midwest
    2022 Prius
  14. Iron Man Prius
    98
    25
    Fullerton
    Three Touring
    Either stay cooler without heat for a couple minutes during warm up 1 month out of the year...or have her headgasket blow stranding her and costing thousands sounds like a no brainer to me.
  15. Mendel Leisk
    41,295
    Everybody’s stated an opinion, time to knock down the tents and move on?
  16. Iron Man Prius
    98
    25
    Fullerton
    Three Touring
    I don't know? It's a discussion forum, there's no official rules there.As long as someone keeps bringing it up, I will keep the conversation going.
