Key Fob Security
Discussion in 'Gen 5 Prius Main Forum' started by Hans Unrat, Nov 18, 2025.
  1. Hans Unrat
    Hans Unrat Junior Member
    30
    I ran across an advertisement for a Faraday bag (which is insulated to stop thieves from copying your fob signal)- after a short web search I discovered that one can de-activate Toyota and Lexus fobs by pressing and holding the lock button while twice pressing the unlock button on the fob. To re-activate, simply press the unlock button to enter the car (when locked, the door will not open by grabbing the handle). Of course, this may be mentioned in the owner’s manual as well, this is for those who haven’t read the whole thing like me.
    futurist and bisco like this.
  2. ChapmanF
    18,316
    Cool!
    Doesn't seem to do anything with my 2010 Gen 3 though.
    PriusCamper likes this.
  3. Templeton
    Templeton Member
    306
    99
    usa
    2024 Prius Prime
    SE
    We use a little faraday box (countless varieties of them sold on amazon), that is far easier to open and close than a bag. And that's where the fob always sits when our gen5 is in the driveway. Because deactivating the fob with button pushes after every car trip would be a huge pain, or so l would think.
  4. otatrant
    otatrant Active Member
    338
    205
    San Francisco
    2023 Prius Prime
    XSE Premium
    I bought these a while back. Keep my keys in them when I am not using them. Don't think those type of attacks are very common where I live but only $13 and pretty easy to use.
    amazon
  5. RRxing
    RRxing Senior Member
    2,548
    1,825
    NEPA
    Try it, you'll like it! ;)
    Much less of a pain than putting the fob in a faraday cage/box every time.
  6. VelvetFoot
    VelvetFoot Active Member
    855
    304
    New York State
    2026 Prius
    Page 133 of the 2026 manual:
    otatrant and Hans Unrat like this.
  7. ChapmanF
    18,316
    I walk in the door, keys go into an old tin someone gave me cookies in.
    I confirmed its sufficient Faraday-ness by walking it right out to the car with the fob inside and trying to get in.
    mva, PrimeDan and Prodigyplace like this.
  8. Doug McC
    Doug McC Senior Member
    1,079
    418
    Midwest
    2022 Prius
    We’ve been doing that since we bought our ‘22 new and still haven’t had to change the batteries. Easier for us than having to stop and put them in a separate container all the time and the fob that isn’t in use when we travel is still asleep.
  9. Hans Unrat
    30
    I think an added bonus could be extending the life of the battery in your spare fob, should you have one.
  10. Blackat
    Blackat Active Member
    463
    321
    Colorado
    2023 Prius
    Limited AWD-e
    Is this, like a city problem? I don't really understand,someone copies your fob while you're walking around then goes to your car and steals it?
  11. ChapmanF
    18,316
    The proximity "smart key" behavior is more of a vulnerability than some might realize.
    The car lets you get in and start it as long as the 'ping' from the car gets a reply from the right fob. Normally, this only works within tight ranges near the car, thanks to the low transmit power of the fob.
    So, normally, nobody can walk up and drive your car away just because the fob is inside the house with you.
    But the person who walks up with an amplified antenna/repeater can do just that. The signals are amplified to cover the greater distance, and the thief gets in the car and drives away.
    Once they arrive at their chop shop or flatbed and turn the car off, they can't turn it on again, but at that point they don't care.
    Hans Unrat likes this.
  12. RRxing
    2,548
    1,825
    NEPA
    That's the main reason I do it every time I leave the car. As a matter of fact, strictly as a preventative maintenance item, I just replaced the batteries on my two fobs today, after 3-1/2 years. The old batteries still worked, but I have noticed the leds getting slightly dimmer, or maybe my eyesight is failing with age. :(
    PrimeDan and Doug McC like this.
  13. Wingman95
    Wingman95 New Member
    CA
    2025 Prius Plug-in
    SE
    Thanks to everyone for a very informative read. I guess there will be Faraday bags in my future!
  14. Templeton
    Templeton Member
    306
    99
    usa
    2024 Prius Prime
    SE
    Cloning someone's key fob while the target is walking around is technically easy, but that would have to be a targeted action.
    More problematic is when thieves with a cloning device are just driving up and down random streets because, with the right equipment, they can ping key fobs that are sitting unprotected in people's houses, receive the return signal from the fob, and then copy the fob code to create a perfect electonic clone of your key fob.
    If your car is parked on your driveway, then they can drive it away as if they have the factory key fob. And they can start and restart your car as many times as they want.
  15. futurist
    futurist Member
    42
    76
    United States
    2024 Prius
    Do both the fob trick and use a Faraday cage at home. Seel on Amazon for ~$6 - $12US... and have tested it works just fine (tho may have to see about a tin can -- that's essentially free once you've eaten whatever was inside it... tho unless it's a paint can... RF can still leak out an open top, can't it? My Faraday keybox has a lid with an overlap of 1" around the rim, and whilst closed can be inches from the car and not be detected.
    May have to check to see how well it protects with the lid open, to test the can method (also concerning, as using your fob behind your chin and opening your mouth towards your car, essentially dbls the range of the signal, due to RF bouncing around and using your skull as a focused antenna. The curve of the inside of the can is very similar, an amplifier? Looking forward to seeing what the results of testing show (n)
  16. otatrant
    338
    205
    San Francisco
    2023 Prius Prime
    XSE Premium
  17. Blackat
    463
    321
    Colorado
    2023 Prius
    Limited AWD-e
    Yep, looks like a city problem.
    Also, my car is garaged. Technology...pffft
    otatrant and futurist like this.
  18. mingc
    mingc Member
    55
    34
    Portland, OR
    2023 Prius
    XLE AWD-e
    What?! This I gotta try. I've noticed that my 5th gen fob needs to be much closer to the car for the buttons to work than my 3rd gen fob did. So, the 5th gen fob is less useful for finding the car with the emergency horn button; by the time you're close enough for the button to work you can already see the car. If this open mouth megaphone trick works, it'd be great! Or, where do I buy one of these key fob amplifiers that the thieves use? (They're not cloners. If it were that easy to clone a fob, replacement fobs would be much cheaper and more easily available).
    #18 mingc, Nov 20, 2025
    Blackat likes this.
  19. Templeton
    Templeton Member
    306
    99
    usa
    2024 Prius Prime
    SE
    Yeah, this most definitely not "just a city problem".
    Maybe not so in middle-of-nowhere, rural Montana, but fob cloning thefts like this have been reported in many, many suburbs.
  20. futurist
    futurist Member
    42
    76
    United States
    2024 Prius
    Yep, right on both counts: it does work with the 5th-gens, and yes earlier fobs and their security systems allowed a lot more range than the XW6# does.
    My guess on why, is when you hit lock/unlock on a 5th-gen fob... there's more interchange of data between the fob and your transceiver and security system in the car, vs. just a straight, simple high-intensity RF 'blast'. The car will default to not responding, rather than compromise the security of the vehicle, if this stream of data isn't correct (basically Toyota's 2020's version of bit-checking).
    I just did this proc this morning getting breakfast. Am so used to absent-mindedly doing the lock on the fob next to the car... my fogey-arse brain has to think, did I actually hear the piano tone...? So look back (now usually about 25 paces from the car), and do it again, making sure to see the signal lamps flash.
    The way this works, is bone reflects RF, whilst the squishier parts in your head, less so. Thinnest part is the roof of your mouth to enter the braincase... so holding the fob behind your chin, in front of your throat and 'firing' the fob buttons... shoots this RF data stream into your head. But your teeth are by far the densest tissue in your head... so need to move them and the rest of the flesh out of the way, just dropping jaw. The RF will reflect off the curved interior of your skull like an amplifying dish, shooting the signal towards whatever your agape gob's aimed at.
    In my 10th-gen Civic (no smart-key system)... could lock / unlock from a ridiculous distance away -- like almost 50m w/ a fresh battery. The XW60... if you're not around 15m away, need to tediously walk towards the car, until it responds. The skull antenna trick increases this to ~20m, maaaybe 25m with clear sightline and perfect aim... but no more ime (y)
    mingc likes this.
