Prius V battery swapped from Nimh to Li-on questions...
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Nicola1, Nov 19, 2025.
  1. Nicola1
    Nicola1 New Member
    Poland
    2013 Prius+ MPV
    Hey, i am legit on my wits end here and decided to seek help here.
    I've recently (20 days ago) bought a Prius V that was converted to a european 7-seat version. They also removed original nimh battery and installed li-on in the middle. Now, the whole issue starts here. Dealer that important the car from USA and converted it in 2021 went the cheapo way and instead of converting entirely with ECU/BSM/ABS swap, they simply trimmed the battery cables from Li-on harness and somehow made them fit into original Prius V driver that's made to work with Nimh battery.
    I bought this car off of a 1st owner that bought this car from this dealer and did 300k km with it apparently with no issue despite this battery setup being an absolute circus. Shortly after purchase i've got hit with P3018 error of block 8, checking on it with Dr Prius showed IE as high as 25 and volt diff while hard braking was as high as 0.8, at the time i didn't have money to replace the battery so i kept driving for next 2 weeks until... well, the entire battery went to hell as the module #8 burned entirely. I towed the car to nearest workshop specialized in swapping these and thats where i got to know what kind of messed up construction this is. They told me they never seen something like this and they can't fully swap the battery because it won't be compatibile with BSM and won't work so best they can do is swap the modules into the "converted" harness and plug it the same way it was, which i said ok because well i didnt have many other choices.
    Here's where the issue starts. Same day i picked up the car, Dr. Prius keeps showing me the same worrying signs that were there with previous modules and balance issue on Block #8. Theres no errors right now, but hard braking slams volt diff to 0.75 and IE on that block is 14, while all others sit at 7, basically its as if modules werent changed at all (they were since the old battery died entirely and i got the burned modules back). Mechanic says to ignore Dr. Prius because it won't show correct data due to wrong driver module and to just keep driving which seems completly off to me because Dr. Prius correctly sees 14 blocks, not 26 that nimh has and previously it correctly spotted issues with faulty block #8. I assume the problem here is not with modules but with harness or busbars or some other connectors around block #8 that causes it to take too much energy/give too little and have way higher resistance. Workshop refuses to take it back because "they checked, it was okay" even tho they didn't do any stress-tests, just checked with voltage is correct, slapped it back in and told me to piss off.
    I know that in order to get this battery to work properly i should invest into proper BSM/ECU/ABS Pump swaps, but thats too much money for me rn and even tho this construction is an abomination, it worked for so long so i assume it should keep working but... Is it possible that Dr. Prius/Hybrid Assistant are mistaken about new modules working out of order? From what i read even tho driver is wrong and BSM treats this batter as if it was Nimh even tho its Li-on, the data it reads is factual so if it clearly shows me such huge voltage difference it comes from something.
    Do i trust the app or do i trust the mechanic and keep using this? I can't afford to degrade those modules again due to overcharge or risk another battery burning down because this fix already cost me 1.1k€. Any advices how to play this out?
  2. rjparker
    10,503
    6,593
    A company in the US tried the same thing replacing nimh for lithium while maintaining the oem nimh BMS. It worked for most people for two or three years before failing. Some also burned. It is an unsafe setup.
    They are being honest with you. I would consider finding used parts designed for lithium but there is no guarantee a US Prius converted to lithium could be properly converted short of changing other ecus as well. However if your shop has experience doing it and knows what parts and software to change, used parts from Europe may be the way to go.
    By the way US nimh batteries have 28 modules monitored in pairs, eg 14 pairs. Nimh is more tolerant of multiple cells wired in series as opposed to lithium.
    From a US nimh scanned by Dr Prius
    #2 rjparker, Nov 20, 2025
    mudder likes this.
  3. Nicola1
    Nicola1 New Member
    Poland
    2013 Prius+ MPV
    This is how it looks for me:
    #1 image is driving slow on EV (clearly #8 is giving way less than all others)
    #2 is stand still on red light
    #3 is hard braking while going down the hill
    Is it possible that these readings are completly wrong due to wrong driver? Thats what my mechanic keeps telling me, yet i cant help to be worried because if #8 is behaving this bad it's matter of few days before it degrades to the same state old one that exploded was and i'll need yet another 1.1k€ replacement...
    Screenshot_20251119_145919_Dr_Prius.jpg Screenshot_20251120_105129_Video_Player.jpg
  4. rjparker
    10,503
    6,593
    It does look like bad modules. The US company added averaging circuits to make their lithium modules look better to the oem nimh bms. Eventually they discontinued the lithium and now sell sodium.
  5. Nicola1
    Nicola1 New Member
    Poland
    2013 Prius+ MPV
    Is it really modules tho? They were swapped literally 2 days ago to a 20k km modules from a different battery. It's too weird that THE EXACT SAME blocks are causing issues that were causing issues on the old ones. Wouldnt it be possible that its something in the harness/busbars?
    Air_Boss likes this.
  6. rjparker
    10,503
    6,593
    Could be based on how the harness was extended to make the move into the front console. I might have your shop measure the voltages at the bms (in back?) again. The fact #8 goes lower than the rest followed by higher the rest seems to discount a bad sensor connection and it's hard to believe they would not have cleaned up corroded bussbars - but that could be a cause
    You are certainly breaking new ground here.
  7. mudder
    mudder Active Member
    280
    384
    Chattanooga, TN
    Sorry this happened to you.
    1: Can you post pictures of the lithium battery that caught fire?
    2: Please post a picture of whatever battery setup you have installed right now.
    3: I assume you've reverted back to OEM NiMH with the OEM Gen3 BSU (same BSU is used in Prius V)(your description is unclear).
    4a: My first recommendation is to replace the BSU computer. This is the computer that measures the voltages you're seeing in the Dr.Prius App. I purchased a couple last year on eBay for $30 each... looks like they're closer to $70 now (but this will likely fall in the upcoming year after LiBSU comes out). PN is 89892-47020.
    4b: The BSU tends to oxidize at the connectors over time... it's certainly cheap enough to swap in another one to verify behavior.
    5: As pointed out above, oxidation on the BMS connections (or on the busbars between cells) could produce same measurement error across multiple packs.
