1. kevinprius416
    kevinprius416 New Member
    Toronto (Canada)
    2015 Prius v wagon
    I picked up a 2015 Prius V the past summer with 130k km (80k miles) which had all service done at a Toyota Dealer. I decided to check on the 12v battery to figure out the age and if I should replace it now that winter has rolled in. I believe the original 12v battery is in the car, 311014 is the code if I'm not mistaken. There is also a 2434 stamp on the casing which could be a 2024 battery?
    Car has had no issues starting or exhibiting any weird electrical issues/inconsistent codes. I do fully intend on replacing the battery if the date code is indeed 2014.
  2. rjparker
    10,068
    6,235
    Looks pretty new. Can't be a 2014 - they don't last that long.
    The definitive test is an old school load test, usually free at an auto supply.
    Air_Boss likes this.
  3. Mendel Leisk
    41,296
    I’d load test it (with one of the electronic load testers), go from there.
    last battery I put in our 2010 was September 2015, still testing like new. I’m using a Solar BA5 (latest iteration Solar BA9).
    note, the pictured battery is an Optima Yellow-Top, with 450 CCA spec, and maybe 38 Amp Hours. Not really optimal for Prius; when I replace it I’ll go with something with specs closer to original, say 325 CCA, and higher Amp Hours.
    #3 Mendel Leisk, Nov 20, 2025 at 8:04 AM
  4. VelvetFoot
    VelvetFoot Active Member
    511
    159
    New York State
    2026 Prius
    While I've never used the old school tester, I have a digital tester and based on my experience, wouldn't trust that too much. It's easy and cheap, but I'm not sure how accurate. Which type do the auto supply places use? I suppose it varies.
  5. BiomedO1
    3,457
    1,797
    SacTown, Ca
    If that car was always dealer serviced; you should be able to pull up the history through it's VIN.
