1. kevinprius416
    kevinprius416 New Member
    Toronto (Canada)
    2015 Prius v wagon
    I picked up a 2015 Prius V the past summer with 130k km (80k miles) which had all service done at a Toyota Dealer. I decided to check on the 12v battery to figure out the age and if I should replace it now that winter has rolled in. I believe the original 12v battery is in the car, 311014 is the code if I'm not mistaken. There is also a 2434 stamp on the casing which could be a 2024 battery?
    Car has had no issues starting or exhibiting any weird electrical issues/inconsistent codes. I do fully intend on replacing the battery if the date code is indeed 2014.
  2. rjparker
    10,072
    6,236
    Looks pretty new. Can't be a 2014 - they don't last that long.
    The definitive test is an old school load test, usually free at an auto supply.
    Air_Boss likes this.
  3. Mendel Leisk
    41,299
    I’d load test it (with one of the electronic load testers), go from there.
    last battery I put in our 2010 was September 2015, still testing like new. I’m using a Solar BA5 (latest iteration Solar BA9).
    note, the pictured battery is an Optima Yellow-Top, with 450 CCA spec, and maybe 38 Amp Hours. Not really optimal for Prius; when I replace it I’ll go with something with specs closer to original, say 325 CCA, and higher Amp Hours.
    #3 Mendel Leisk, Nov 20, 2025 at 8:04 AM
  4. VelvetFoot
    VelvetFoot Active Member
    511
    159
    New York State
    2026 Prius
    While I've never used the old school tester, I have a digital tester and based on my experience, wouldn't trust that too much. It's easy and cheap, but I'm not sure how accurate. Which type do the auto supply places use? I suppose it varies.
  5. BiomedO1
    3,461
    1,798
    SacTown, Ca
    If that car was always dealer serviced; you should be able to pull up the history through it's VIN.
  6. rjparker
    10,072
    6,236
    If the "old school" load tester (still available everywhere) has analog meters and ventilation it is more likely to be accurate. The better units are called "carbon pile" load testers.
    BiomedO1 likes this.
  7. BiomedO1
    3,461
    1,798
    SacTown, Ca
    I think harbor freight still has the lower pictured one for around $20; pretariff price. That intel is more than a year old....:(
  8. rjparker
    10,072
    6,236
    The David Letterman Battery Tester
    #8 rjparker, Nov 20, 2025 at 1:18 PM
