Disease Prevention and Health Reseach
Discussion in 'Environmental Discussion' started by tochatihu, Mar 29, 2025.
  1. bisco
    51,840
    if vaccinations don't work, what are the antibodies they find upon testing doing?
  2. frodoz737
    frodoz737 Top Wrench
    4,692
    2,492
    33
    If these vaccines worked...how come everyone still caught the bug?
  3. ChapmanF
    18,066
    Do you still think the vertebrate immune system works like Star Trek deflector shields?
    fuzzy1 and bisco like this.
  4. frodoz737
    4,692
    2,492
    33
    I repeat...If these vaccines worked, how come everyone still caught the bug? Fact...active shooters are still catching it.
    #104 frodoz737, Nov 20, 2025 at 4:19 PM
  5. bisco
    51,840
    not everyone caught the bug, but vaccines don't always prevent getting it. they prepare your immune system so it's ready to fight the virus if encountered.
    do you have any idea how many peole vaccinated for the flu die each year?
  6. frodoz737
    4,692
    2,492
    33
    I know first hand and through observation they do not work and will state it everytime I hear someone who says otherwise. FYR...I was one of those that was mandated by .gov to get the these shots or loose my career...and everything that infers. I followed said "orders", masked up, distanced, everything...and I still caught the bug 3 times "confirmed".
    So...You go right ahead and get your shots for the flu/s, COVID...or whatever else they are marketing today.
  7. fuzzy1
    10,405
    If the vaccines didn't work ... how come vaccinated people had a considerably lower death rate from this disease than unvaccinated people of the same age groups?
    I posted details here showing this 3 - 4 years ago. I believe several others posted similar findings from additional sources.
    Yes, it didn't completely prevent cases nearly as well as numerous people initially said it would. But it very clearly reduced severity and hospitalizations and death rates.
  8. frodoz737
    4,692
    2,492
    33
    This bug mutated and became less viral...period. Even our College boy from China said this "would" happen way back when everyone was still walking around with dirty designer rags on their faces. Claiming a reduction in severity, hospitalizations and deaths became the fall back when these shots did not deliver as first advertised. The psyops worked...the shots did not. The bug is still out there and you still get it...with or without the shots.
  9. tochatihu
    tochatihu Senior Member
    9,758
    3,761
    Kunming Yunnan China
    2001 Prius
    There is a possibility that people inclined to obtain vax (specifically those not forced to do so) also had other behaviors such as wearing masks effectively, social distancing, hand washing, avoiding face touching. Those behaviors could reduce viral loadings with effect of slower viral production in corpus. Slower viral production would allow immune system to protect better. One is only naive until virus is onboard and immune system notices.
    There is a possibility that behaviors could lower death rates. It is not amenable to epidemiological study, but that does not rule out any possible contribution. I mention all this because even untestable possibilities ought to be recognized.
    Ignorance of vaccine efficacy studies is an object of derision or at least dismay here. I do it meself. But let not our other (smaller) ignorances sneak in.
  10. frodoz737
    4,692
    2,492
    33
    ...and how did you survive again without Pfizer and Moderna? That's a rhetorical BTW.
  11. tochatihu
    9,758
    3,761
    2001 Prius
    "This bug mutated and became less viral...period. Even our College boy from China said this "would" "
    That understanding of virus ecology comes from wiser sources than I. But let us not say it became less viral ... descending variants became less lethal. That along with a requirement to evade immune systems continuously being improved by vaccines and survived infections.
  12. tochatihu
    9,758
    3,761
    2001 Prius
    I got 3 times Sinovac, all identical debilitated viral strains AFAIK. I hid at home to the extent possible and took appropriate precautions when out. Numerous swab tests all indicated absence of COVID infection. There was a long time when one could not travel beyond local bus distance without swab tests 'in the green'.
    in 2024 I got one strong infection that was more likely RSV (based on what was going around at the time). It was a bad week but I have read of worse around here.
  13. frodoz737
    4,692
    2,492
    33
    Less lethal...as in clearly reduced severity, hospitalizations and death rates.
  14. fuzzy1
    10,405
    Claiming that because the shots did not deliver as first commonly advertised, they therefore must not work at all, is a logical fallacy.
    Remember also that I posted warnings in this very forum, long before any vaccines existed, that vaccine immunity might fade quickly, based on our experience with the 4 prior coronaviruses that cause common colds. (Rhinoviruses seem to be the greatest cause of common colds, coronaviruses are usually listed as second. There are also additional causes.) Statistically, it appears that on average, humans in the U.S. get each of the 4 common-cold coronaviruses about 10 times per lifetime, suggesting that those natural immunities from previous infections fade fairly quickly. (Rapid mutations not considered in this figuring.) So don't be surprised of Covid-19 immunity does the same.
    My warning on this, is essentially what ended up happening.
    #114 fuzzy1, Nov 20, 2025 at 11:29 PM
  15. tochatihu
    9,758
    3,761
    2001 Prius
    Here is a recent publication link on the whole COVID thing:
    https://link.springer.com/article/10.1007/s12223-025-01299-9
    What's done is done, that learned is learned, and that unlearned is unlearned.. It would be lethally presumptuous to presume that no future zoonosis will affect humans. Most we hope will be like 'the chicken thing' that made eggs more expensive but has not (yet) crossed over. When a bad one does, we'll rely upon traditional public health measures, traditional vaccines, and new mRNA vaccines. I strongly doubt that unlearners can influence general outcomes towards the negative.
  16. frodoz737
    4,692
    2,492
    33
    I've heard all the opinions, excuses and crawdads I need. The shots did not work to cure, prevent, stop the spread or lessen any of the effects of SARS-CoV-2 on humans. We were all lied to.
    “It's easier to fool people than to convince them that they have been fooled.”
  17. bisco
    51,840
    repeating your position over and over does not make it correct. presenting evidence beyond 'i know first hand and through observation' would be helpful to your case.
    btw, president trump received his fall flu and covid shots a few weeks ago.
  18. fuzzy1
    10,405
    You can lead a horse to water, but ...
  19. fuzzy1
    10,405
    Yes, even P45 chose, and P47 still chooses, to voluntarily get the flu and Covid-19 immunizations. Even he understands some things that significant portions of his base do not.
  20. frodoz737
    4,692
    2,492
    33
    Interesting you guys keep forgetting...I did comply with the shot mandates and followed all the guidelines. Oh...and I worked during that two week vacation President Trump gave some of you.
