Is one of my TPS sensors failing... Or something else?
Discussion in 'Gen 4 Prius Technical Discussion' started by ticedoff8, Nov 20, 2025.
Tags:
  1. ticedoff8
    ticedoff8 Junior Member
    52
    San Jose
    2016 Prius Touring model with around 100k miles.
    Replaced the tires at 65k and all has been well.
    I'm trying to figure out if one or all my TPS sensors are failing or it's something else.
    About 2 months ago, before a 300mi trip, I topped off the pressure on all 4 wheels to 37psi and it was around 65F ambient when I pumped them up. I like this pressure when the weather cools down and it gets up to 39psi after driving (I use 34psi in the summer).
    I was driving over a mountain highway from the valley floor (300'msl) and over the peak (1400'msl) and then down to another valley (400'msl). On the uphill drive, the TPS warning came on and I pulled over on a turnout (shutoff the car) and checked the pressure - they were all 37 to 38 PSI. Started up and the TPS warning came back on. At the bottom of the mountain road, I got on the Interstate and set the CC for 80mph. At some point, the TPS want off and didn't come on again - until 2 weeks later when I made the same trip on the same road and the TPS warning came back on, and it was around the same location.
    It never happened on the return trip.
    I thought it was weird.
    I topped off the wheels ago about a week ago, and it has started happening now when I am just driving around locally on the freeways.
    It came on when I had my wife in the car, and she pointed it out right away while it was still blinking. I told her to wait and see if turns off. And it did, about 20 mins later.
    I assume that the TPS uses air pressure and not wheel speed sensors. And I assume it will not show a warning until there is a 3 or 4 psi delta between tires or if one (or all) of the sensors drop below (I think) 28psi.
    Am I due for a new set of TPS sensors?
    Do the sensors detect when the pressure it too high?
    The portable compressor I used is the type that I can dial in the psi I want, connect it to the wheel and press the button. It will stop when it gets to the setting. I checked it when it was new with 2 of my digital pressure gauges and it's accurate. And, when I use it on my Leaf (which has a dashboard screen that shows all 4 tire's PSI) and its displays agrees with the compressor when I finish.
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,474
    2,437
    Taylors, SC
    On my 2012 Prius v, one of the batteries in a sensor died.
    Having driven 40 years before the advent if TPMS and regularly checking tire pressure without TPMS, I decided that I did not want to spend $300 to $500 to replace them.
    Over the past couple of weeks, I located the TPMS computer behind the lower glove compartment and using a wire jumper, I just turned off the warning light under the dash.
    amos and VelvetFoot like this.
  3. amos
    amos Active Member
    372
    283
    los angeles
    Can you pleasr share this jimper you did. With photos or more info?
  4. Georgina Rudkus
    3,474
    2,437
    Taylors, SC
    Sure, it's position 5 five and 6.
    It might have different colored wires, but it's the same position on the regular Gen 3 Prius.
    I used a thin single wire from a Cat5 cable. A telephone line wire will also do.
    Instead of a 3M clamshell connector, I just inserted the skinned wire ends from the back.
    That way, if you got new TPMS transmitters, just pull the jumper, and it will look like it was never there.
    Here's a photo of my installation.
  5. amos
    amos Active Member
    372
    283
    los angeles
    Really simple.
    I had to drive down to tijuana to get my sensor issue takencare. Didnt cost much .like 15$ labor and 10$ for a china made tpms. Works fine.
    Next time i'lĺ just have a jumper there . Guess it can be done in any car. Good to know
  6. ticedoff8
    52
    San Jose
    How did you pair the new sensors from China to the car? I've only heard that it is a pain and almost impossible.
    If you still have the 2016 Prius, I would assume the China sensors would work on mine too. Do you have a source I can use?
    amos likes this.
  7. ticedoff8
    52
    San Jose
    amos likes this.
  8. amos
    amos Active Member
    372
    283
    los angeles
    #8 amos, Nov 26, 2025
    ticedoff8 likes this.
  9. ticedoff8
    52
    San Jose
    Did you have to use a special tool to "reprogram" the sensors?
    The only option in the car's Maintenance > TPMS dashboard is simply labeled "Reset TPMS".
    amos likes this.
  10. amos
    amos Active Member
    372
    283
    los angeles
    the programing was done by a hand scanner at michelin tites. didnt do it myself.i only had a chance to see the programing choosing car model etc..didnt mind its a chinese sensor.
    was a very simple thing for them
