Key Fob Security
Discussion in 'Gen 5 Prius Main Forum' started by Hans Unrat, Nov 18, 2025 at 8:32 PM.
  1. RandyPete
    RandyPete Active Member
    403
    167
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    I thought the last Gen 3 was a 2009 model !?
    OOPS,I was thinking of a Gen 2 !
  2. ChapmanF
    18,064
    The ordinary cookie tin I'm using is quite effective, can take it within inches of the car and still no entry.
    I made an earlier attempt with a locking metal key box that I lined obsessively all around the hinges and gaps with conductive foil tape. Never got it to be effective.
    futurist likes this.
  3. futurist
    futurist Member
    33
    United States
    2024 Prius
    That's interesting -- the Faraday cage box I use has a mesh in it (Amazon seller sent one damaged, so they replaced it and I got to dissect the broke one). Supposedly the pitch of the mesh has to do with how much RF it can block (like how the see-thru perforated screen on your microwave oven door keeps the magnetron's RF in)... so the finer it is, the more effective for more frequencies. But if the can works but the metal box doesn't... perhaps the flat sides of the box are actually amplifying the signal instead of blocking it? And the open can's only leak is directly upward?
    Guess some commo engineers will need to chime in; eager to learn why :coffee:
  4. ChapmanF
    18,064
    For clarity, I don't use the cookie tin open. It has a reasonably tight-fitting lid, painted with green foliage and a floral wreath.
