How To Clean The Infotainment Screen?
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by VelvetFoot, Nov 12, 2025.
  1. VelvetFoot
    VelvetFoot Active Member
    531
    164
    New York State
    2026 Prius
    Smudgy fingerprints, seen when screen is off, mostly.
    I try to be careful.
    Manual isn't too descriptive-no harsh chemicals, soft cloth.
    I don't want it to turn into the cure is worst than the ailment.
  2. Mendel Leisk
    41,305
    Damp cloth. Follow up with dry cloth.
    VelvetFoot likes this.
  3. VelvetFoot
    531
    164
    New York State
    2026 Prius
    Would that do the trick for smudgy finger marks? I'd think you'd need a solvent of some sort, but potentially dangerous to plastic.
  4. Mendel Leisk
    41,305
    Try damp cloth first. Our son cleaned his CX-5 touchscreen with some "interior cleaner", left it milky, he resorted to adding a screen protector. Replacement touchscreens can cost thousands, so good to start with the most innoxious possibilities. Or just ignore it?
  5. VelvetFoot
    531
    164
    New York State
    2026 Prius
    On my relatively new MacBook, Apple says water-dampened cloth.
    Doesn't really get rid of fingerprints, but it's not a touch screen either.
    I'm thinking, if the screen is on, not noticeable, just when off.
    I kind of like the car display dark, a lot of times though.
  6. BiomedO1
    3,481
    1,807
    SacTown, Ca
    Use a tint-safe glass cleaner and spray it onto a microfiber towel - don't spray it directly onto the glass. You can test it in a inconspicuous corner of the screen, if your not sure. I do the same with all my computer screens. Unfortunately, I can no longer 'borrow' those really expensive screen cleaning towelettes, since I've retired. They do require a bit of elbow grease, since the solvents aren't that strong. If there's a layer of dust on it; use something like a swifter to pull that off the screen FIRST; so you don't inadvertently scratch it when applying the damp cloth with elbow grease.:p
  7. VelvetFoot
    531
    164
    New York State
    2026 Prius
    Thanks. I'll have to look around for a specialized cleaner.
    edit: I only wish it was glass. :)
  8. kev604
    kev604 New Member
    22
    Vancouver, BC Canada
    2026 Prius Plug-in
    You can use something like Invisible Glass. Spray on to a microfiber towel and gently wipe the screen and done.
  9. mingc
    mingc Junior Member
    36
    17
    Portland, OR
    2023 Prius
    XLE AWD-e
    I use a very small amount of Rain X Glass Cleaner sprayed on a microfiber cloth. So far so good.
  10. broderp
    broderp New Member
    Wednesday
    OH
    2024 Prius
    Limited AWD-e
    I use a microfiber cloth. I also bought this:
    Helps a lot, the screen is not as sensitive with a glass screen protector to rubbing or damage. The glass does increase reflection a little but it has been a good addition.
  11. VelvetFoot
    531
    164
    New York State
    2026 Prius
    That link didn't show up, for me.
    edit: I did find similar screen protectors on Amazon.
    I'll give it a whirl.
    I'll have to give the screen a good cleaning first though, lol.
    #11 VelvetFoot, Nov 19, 2025 at 6:27 PM
  12. VelvetFoot
    531
    164
    New York State
    2026 Prius
    I just installed one. Seems to have turned out okay despite me having to freelance a bit from the instructions.
    In the dark garage, it almost looks like a bit of a matte finish to it, rather than shiny.
    First touches seem responsive.
    More use and time will tell the tale,
    I like that you don't have to be concerned about making scratches in the original plastic screen.
    Thanks for the tip.
    This is the one I got.
  13. sclevine
    sclevine Active Member
    160
    155
    Northeast Florida
    2024 Prius
    Regarding cleaning the screen, mine was fully loaded with fingerprints and smudges, and I just gave it a good hard rub with a microfiber cloth, the ones you get to wipe eyeglasses or laptop screens, and all the fingerprints came out very easily. Just the dry microfiber cloth.
