Wheel and Tire fitment and TPMS questions
Discussion in 'Gen 5 Prius Main Forum' started by kev604, Nov 6, 2025.
  1. kev604
    kev604 New Member
    24
    Vancouver, BC Canada
    2026 Prius Plug-in
    New owner here of a 2026 XSE Premium PHEV so I apologize if some of my questions have been asked and answered.
    First off can someone confirm the wheel specs for the 19s are 19x6.5 +40 offset and 17s are 17x6.5 +40 offset?
    The 19s on the Prius as we all know with those oddball wheel specs tire options are very limited. The few AS tires offered in 195/50/19 are pretty trash although Michelin does make the X-Ice Snows in this size. I've had experience with the X-Ice Snows and they are excellent tires and well suited for my driving environment so if I mount X-ICE Snows on the 19s I'll need a second set of wheels.
    For a second set of wheels I'd be looking at a slightly wider wheel in 18s or 17s so I have more tire options. If I go wider wheels and tires I am concerned about strut clearance does anyone know how much strut clearance I have over the stock spec wheels if I go wider? Again I'm not out to slam it or turn it in to a race car just looking for more tire options if possible.
    I've also been researching the TPMS. Am I able to buy TPMS at the tire shop and clone them to the car? I know I did that with my wife's old.Nissan and that worked flawlessly.
    TIA
  2. Tideland Prius
    16,547
    otatrant likes this.
  3. reservoirblue
    reservoirblue Member
    95
    73
    Woodacre, CA
    2024 Prius Prime
    SE
    Just search tire options here on this site. I've had 215-55-17 on the original rims for a while.
  4. kev604
    kev604 New Member
    24
    2026 Prius Plug-in
    My wheels are 19s so there aren't narrow tire options available on 19s.A 215/45/19 tire for example doesn't exist. I like the stock wheels but the OEM Toyo's are sub par so looks like the only way to upgrade my tires would be to invest in new wheels and mount snow tires on the OEM wheels.
  5. kev604
    kev604 New Member
    24
    2026 Prius Plug-in
    Offset?
    A 17x7.5 wheel with say a +40 offset the wheel would then sit 13mm closer to the strut and poke out 13mm further than stock. Without actually trying I'm guessing something like this will fit but you'll have to size your tire carefully probably a 215 wide tire on the safe side a 225 wide tire would be wise to test out first
  6. Tideland Prius
    16,547
    All the specs are in that link.
    I think 215 should be ok. 225 is likely pushing it.
  7. Hammersmith
    Hammersmith Senior Member
    2,302
    2,316
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Just putting it out there again that Michelin should be selling the CrossClimate 3 here next year in 205/50-19 which will work on the OEM wheels. It's currently being rolled out in Europe.
    Just throwing it out there as an option for those considering considering new wheels just to get better tire options.
    GeoJ and Tideland Prius like this.
  8. kev604
    kev604 New Member
    24
    2026 Prius Plug-in
    That's good to know and will benefit a lot of people. I've always been a dedicated snow tire guy and run two sets of tires and will probably do the same on the Prius.
  9. kev604
    kev604 New Member
    24
    2026 Prius Plug-in
    What tire pressure are you guys running on OEM tires and aftermarket/winter tires? When I first checked I was surprised to see a staggered tire pressure set up for the OEM 19 inch tires.The dealer loaded all 4 tires to 35 PSI so I dropped the tears back to 33 PSI per spec but I might bump the rears back to 35 all around.
  10. Hammersmith
    2,302
    2,316
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I typically run +2psi. So 37/35. Others run significantly more. I try to strike a balance between a little more efficiency without making the ride too rough. I'd probably drop back to stock if I expected really bad winter weather, but I'm too lazy to actually do it.
  11. kev604
    kev604 New Member
    24
    2026 Prius Plug-in
    Is there a reason you know for the staggered tire pressure setup? I do find 33 PSI a bit low probably will run 35 PSI all around. I'm planning to mount 215/55/17 snow tires next week will run 36 PSI on the taller tires.
  12. Hammersmith
    2,302
    2,316
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Don't know the reason for it, but I figure Toyota does.
  13. kev604
    kev604 New Member
    24
    2026 Prius Plug-in
    So I've made an appointment on Tuesday to mount snow tires. Here is what I've got. A set of 5x114.3 alloys and tires off my previous car. Wheel specs are 17x7 +45 with 215/55/17 Michelin X Ice Shows. Got some 73.1-60.1 hubcentric rings ready to go. Spoke to the tire shop and will be purchasing a set of new sensors from them which they will clone to the car. The stock wheel specs versus new wheel specs the new wheel will sit 11mm further in and 1mm further out, overall diameter is -10mm, overall ride height is -5mm and speed error is +1.5%. I don't foresee any fitment issues.
    I also have a set of wheels spec 17x7.5 +38 which I think would actually fit better that I could use but just going to keep it simple for now and use the wheels and tires already mounted.
