2014 Prius V want to avoid head gasket problems
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Mountweasel64, Feb 20, 2024.
  1. ksyolsen
    ksyolsen Junior Member
    55
    Haslett, MI
    2013 Prius v wagon
    Sounds like a good plan.
    Is it just the Engine Coolant Temp sensor? Or are there other live data points I should watch.
    Also, side note: Is this piston head indicative of steam cleaning from coolant? Or just a clean piston? (Maybe the previous owner did an engine treatment or something? Idk) there are no other signs of HG failure so it would seem odd to me that it’d be a coolant leak, but it does seem rather clean for 166k miles
  2. Tim Jones
    Tim Jones Senior Member
    1,757
    565
    SE Texas
    2011 Nissan LEAF
    Then u have the traction battery..... the master cylinder and pump.... $4000.... plus the inveter can blow at anytime......
    The cars are junk.................. when older.............. sure low miles seems great........ you have been warned...... keep reading on here........ and other websites..... save your self huge mental and financial pain.
    BiomedO1 likes this.
  3. BiomedO1
    3,494
    1,815
    SacTown, Ca
    That's way too clean for 166K miles. How does it compare to the other 3 cylinders and look at the spark plug burn pattern and color.
  4. rjparker
    10,082
    6,248
    Steam cleaned
    I would suspect head gasket sealant was added for a temporary fix. It usually does a great job - for a few months. I would suggest if it is still running smooth on cold startup by March you bought a good one.
  5. ksyolsen
    55
    Haslett, MI
    2013 Prius v wagon
    I checked cylinder 1 and 2. Similar state, didn’t check 3 and 4 because the spark plugs were all similar and I was defeated that night haha
  6. rjparker
    10,082
    6,248
    Those plugs could be original.
    ksyolsen likes this.
  7. ksyolsen
    55
    Haslett, MI
    2013 Prius v wagon
    Damn
    So no need to panic and do anything right now about it? Just monitor for further symptoms of typical HG failure and if I make it to March I *should* be okay?
    Ugh
  8. ksyolsen
    55
    Haslett, MI
    2013 Prius v wagon
    Yeah, my thought as well. Threw some new ones in while I was in there
  9. BiomedO1
    3,494
    1,815
    SacTown, Ca
    They may have been burning some additive or seafoam. Only time will tell. Some of those harsh additive can destroy your CAT.
    The real silent killer is running that engine hot - that electric water pump isn't going to tell you it's failing; but that HUD will give you advance warning to sniff around. Normal operating temperature is 185F to 205F; even on the hottest summer days and long hill climbs. Touching 210F should be a rarity. Just look around to see if that operating temperature is warranted.
    That spark plug should be black carbon to white ash; don't know what that brown stuff is.
    Good Luck....
    #29 BiomedO1, Nov 21, 2025 at 4:45 PM
  10. rjparker
    10,082
    6,248
    Od
    Odds are in your favor by then.
  11. ksyolsen
    55
    Haslett, MI
    2013 Prius v wagon
    Question that came to mind:
    If there was an active coolant leak causing steam cleaning of the piston, wouldn’t the spark plugs also be abnormally clean as well?
  12. ksyolsen
    55
    Haslett, MI
    2013 Prius v wagon
    So far with the new water pump, it doesn’t appear to go above 190ish which is a good sign. Will continue to monitor.
    Also, everything that I’m reading online says the brown spark plugs is a normal sign of a healthy engine, so I’m not sure what to make of the condition of the plugs.
  13. rjparker
    10,082
    6,248
    Head gasket sealer can stop an active coolant leak. These engines are also known to burn oil. The pictured plug looks like chunks of buildup have fell off the electrode.
    Again you will learn more as time goes on. Watch the passenger side coolant reservoir and the oil level.
  14. rjparker
    10,082
    6,248
    By the way these engines don't exhibit "typical" hg symptoms in the early stages. Leakdown and compression will be fine, combustion gas in the coolant will be negative, coolant loss will be non existent and no milky oil.
    Early symptoms are very occasional severe rattling and shaking on cold startups. Occasional can mean weeks. Then an occasional misfire code which may present on random cylinders but clears within seconds and the engine runs smooth the rest of the day and maybe for several days.
    The severe rattling is enough to convince people to do something. It sounds like rod knock but it goes away quickly. Shops not gen3 Prius fluent fire the parts cannon, plugs, coils, egr cleanings and maybe injectors. Each time there is a warm feeling for days it was solved. Only to return if the very slow early leak remains.
    Borescope is the definitive test. Steam cleaned pistons don't normally happen just by using additives. If the leak is active a borescope on a cold engine with a manually pressurized coolant system may show drops of coolant coming from the gasket into the cylinder. If someone used sealer, no symptoms or coolant drops.
    This video shows a cold engine borescope test using a quality articulating or dual view borescope.
    Car Care Nut HG Borescope at 660s
    Once again, don't worry about it unless you get the symptoms of severe rattling and shaking that goes away for the rest of the day.
    #34 rjparker, Nov 21, 2025 at 10:54 PM
    ksyolsen and douglasjre like this.
  15. douglasjre
    douglasjre Senior Member
    2,164
    715
    Null, NL
    "I would like to enhance my ownership experience" equates to "Im sheep and would like someone to follow. Here's my wallet. Take what you like and Take me to your leader " :sneaky:
  16. douglasjre
    2,164
    715
    Null, NL
    How does glue added to the coolant stop 2,000 psi combustion pressure?
  17. rjparker
    10,082
    6,248
    Most don't realize the leak passage is incredibly small and normally only leaks with the engine cold. Heat expands the mating surfaces and seals it in the early stages.
    The sealant is designed to crystallize under combustion heat according to the sealant manufacturers and clog up narrow openings.
    The bottom line is it does work for a few weeks to a few months. It also clogs radiators, heater cores and even coolant reservoirs making a bad situation much worse. However desperate owners, clueless shops and especially car flippers use it.
    The sealant stays in the system and may renew itself at the leak site as needed.
    #37 rjparker, Nov 22, 2025 at 1:25 PM
  18. Mendel Leisk
    41,319
    Not sure if it's universal, but one stop-leak product maker recommended a 50/50 mix of water/white vinegar to flush out the product. If you find some crystals (like above), you could experiment: drop them in such a mix, see if they dissolve.
  19. ksyolsen
    55
    Haslett, MI
    2013 Prius v wagon
    The coolant looked normal to me, here’s a video of some of it. https://youtube.com/shorts/dd6bJvl_LNg?si=RI7ajwc36VsQuYDo
    Water pump and thermostat looked perfectly clean as well other than some white that looked like maybe coolant that had seeped out and got hot which left the additive behind. But no large amount of anything other than clean looking coolant.
    Should I sell it and cut my losses like some suggest? Or is it worth keeping and just fixing the head gasket when the time comes? I don’t want to sell it and start over with yet another car but I also feel like I made a mistake getting this and reading how people say it’s a money pit.
  20. Tim Jones
    1,757
    565
    SE Texas
    2011 Nissan LEAF
    YES!
    Have your read up on the $$$ Brake Booster? Will go out ...... $1500 if u do it yourself then complicated brake bleed.
    Traction Battery? $$$$$$$$$$$ go out for sure
    Inverter? Can go out at anytime.... but probably coverd under toy but very inconvenient if out of town and if they have the parts
    #40 Tim Jones, Nov 22, 2025 at 4:30 PM
