2012 V: Trouble removing OEM front wipers
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by OldGuyInTheClub, Nov 22, 2025 at 7:50 PM.
  1. OldGuyInTheClub
    OldGuyInTheClub New Member
    Yesterday
    Los Angeles
    Long time lurker, first time poster.
    I've changed my wipers a few times over the years without much problem. I am currently struggling to remove the front wipers which are OEM Toyota parts from my local dealer. They refuse to come out with moderate effort and I don't want to exert any more force until I get advice.
    There's a tab to flip up and normally I'd just pull to disengage from the hook end. But, neither front blade unit will come off. I looked for another tab or clip that would need actuation and can't find anything appropriate.
    Due diligence: I've watched a lot of YT videos and searched the Forum. The Forum has several older posts about this but a key photo is not appearing in the messages. I am doing what the videos say and they're all in line with what I've done in the past but the blade/frame won't come off this time. I'm replacing with Anco blades so I don't have any OEM removal directions.
    I've enclosed some photos of the assembly from various angles. I can upload higher resolution images if needed.
    Advice appreciated.
  2. rjparker
    10,083
    6,250
    A little oil on the hook might help. You push not pull to remove.
    For Video - White Arrow then Red Arrow
    Stills
    #2 rjparker, Nov 22, 2025 at 10:55 PM
    Brian1954 likes this.
