How to choose synthetic oil?
Discussion in 'Gen 3 Prius Main Forum' started by taxce, Nov 22, 2025.
  1. taxce
    taxce Junior Member
    28
    california
    I’m planning to go to Walmart auto care Center soon for an auto oil change and I noticed they offer three different options in order of increasing price: Quaker State synthetic - full synthetic - premium synthetic.
    Is Quaker State sufficient for the average car’s needs or is there a reason to go with premium?
  2. Mendel Leisk
    41,849
    Coonsider also Walmart's house brand Super Tech. It's actually made by Warren Distribution, the same source for Costco's Kirkland oil. I've been using the latter for a few years now, seems fine, and less pricey than the mainstream brands.
    Here's Mr. B's exhaustive review of the later, comparing to Mobil 1. I literally fell asleep about half way through, when he got into the deep tech:
    taxce likes this.
  3. bettergolf
    bettergolf Active Member
    493
    369
    Sanford NC
    I have used Walmart Supertech synthetic oil for about 30 +years....no problems. It's more about changing your oil regularly than which brand you use.
    BiomedO1 and taxce like this.
  4. BiomedO1
    4,058
    2,136
    SacTown, Ca
    I use the Supertech full synthetic too; but I spring for the extra dollar and use the 20K mile formulation. It contains more anti-wear additives. I've only been using it since 2012, starting with my old Prius C.
  5. Albert Barbuto
    Albert Barbuto Active Member
    113
    104
    Northeast USA
    [QUOTE=" It's more about changing your oil regularly than which brand you use.[/QUOTE]
    This...
    Georgina Rudkus likes this.
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,508
    2,487
    Taylors, SC
    If the jug has the same larger sized cap as Mobil 1, the Walmart Super Tech oil is made by Mobil 1.
    Warren Distribution has several manufacturers making their oil. Mobil 1 is one of them.
    The Mobil 1 production line machinery uses a particular sized cap. Changing the cap size would require expensive extra cost.
